Results 41 to 80 of 113
Thread: First 818 COUPE build
    Wow, he's getting after it. What's that reinforcing on the hood?
    Quote Originally Posted by TouchStone View Post
    How did you add the support to the hood?
    Balsa sandwiched in fiberglass.
    BN's Avatar
    Sept-lies Qc.Canada +FL. Danvenport
    Hi lance are you installing the wiper kit?
    BN's Avatar
    Quote Originally Posted by BN View Post
    Or Bob n Cincy
    Nice, I want to do the same thing to the hood.
    Sep 2015
    Hamersville, Ohio
    I simply went to my local auto parts store and bought a siamesed tube of panel adhesive(2 part epoxy) to glue the balsa wood to the hood bottom. 50 grit sandpaper to prep, then fit the wood. I sawed grooves in the planks 4/5 of the way through, allowing the wood to conform to the contour of the hood. After gluing the wood to the hood, I filled the saw grooves with the same panel adhesive, effectively locking in the contours. After all that, another round of 50 grit in prep for the fiberglass. 3 layers of glass cloth & resin completed the job. It's so stiff now, it's unbelievable.
    Sep 2015
    Hamersville, Ohio
    The supplied wiper kit requires trimming of the hood. This doesn't appeal to me, so I may seek an alternate method of operation which allows the hood to remain untouched.
    Thx for the details. Would not have thought to make the contour slits.... clever!!
    Senior Member Loring's Avatar
    Nov 2015
    Lakeland, FL
    Lance, if you're able to, can you get a photo pf what the new style headlamps look like when they're lit up?
    Thanks.
    Quebec, Canada
    Quote Originally Posted by Loring View Post
    Thanks.
    Yep, would like to see them
    BN's Avatar
    I was thinking maybe use that piece put it over fix it with somme fiber glass it will be like a hump
    Hey everybody
    Lance sent me a bunch of pictures, I'll post the body mods tonight.
    He opened up the side vents and filled in the original fuel filler opening. I think these side vents will bring twice the air into the engine compartment.
    Here is an awesome look at the new nose.
    He is funneling all the frontal air into his radiator.
    He sent me a bunch of pictures, I'll post some each day.
    Denver, CO
    Awesome thanks for photos
    Here is sme of Lance's gas Tank pictures.
    Frame mods will be next!!!
    Denver, CO
    Was the fiberglass just bent in to open those ducts up more? I want to do this also and was wondering if the fiberglass will just destress over time/ sitting in sun.
    Puyallup, WA
    Quote Originally Posted by bbjones121 View Post
    My experience with fiberglass and putting it under stress like this is that it will eventually conform to the bend and will not have any forces to worry about.
    Jul 2014
    Strathroy, Ontario Canada
    LOL, Looks just like what I did, It makes it look much nicer. cool
    USA
    That gas tank is a great design. How many gallons does it hold?
    If I recall correctly, It is 13 gallons.
    Lance designed the tank and Boyd welding manufactured it.
    Now for Lance's Frame Motifications
    Do you guys like pictures full size or as thumbnails that you can click on?
    Front Bumper frame design
    Windshield mount with locator bracket.
    Large single fan wit custom shroud
    Custom mount of rear side sails.
    Lance added bars along all body seams.
    Rear bumper for safety and to meet Ohio's code.
    Lance used a single bar for the shock cross bar.
    Front bumper for safety and to meet Ohio's code.
    Lance reminds me of Wayne and Erik building the first 818S. They were setting the bar pretty high.
    Sep 2015
    Hamersville, Ohio
    I just slit the side sail along body line and then cut some sticks to wedge the opening to the desired width. Leave the sticks in until fiberglass sets up.
    I did structural glassing from back side, finishing up the cosmetics on the outside.
    Sep 2015
    Hamersville, Ohio
    Bob is correct. The modified openings are roughly twice as wide as stock. They now measure ~4" at top and ~2" at bottom.
    Leesburg, VA
    Very nice work on the frame mods
    San Diego Ca 92106
    Lance, do you have a need for your shock crossbar? I'm in need of one since mine is missing. One of the hazards when buying an unfinished project.
    San Diego Ca 92106
    How much adjustability have you built into your body mounts? Are you doing all the body mounting and fitting first? I was wondering if getting this done first would keep the inevitable dust from getting Ito everything.
    Feb 2014
    Ramona, CA
    I also like the frame modifications/additions. You've added some stuff that I would have copied 8 months ago.
    Edit: I like the thumbnail pictures. Faster loading.
    Great idea on the locator bracket for the windshield.
    Sep 2015
    Hamersville, Ohio
    I would like for you to have my stock shock bar. Pay for shipping. It really isn't much to look at. Looks like a beginner tried to weld it. Lots of ground off welds makes it look bush league. Plus its twice as heavy as the bar I replaced it with.
    Sep 2015
    Hamersville, Ohio
    Looks like FFR could easily cut these pieces when cutting a-pillar lowers. Just my " builder's discretion" to do mine this way. I have no idea if others are doing this already.
    Sep 2015
    Hamersville, Ohio
    I've slotted the brackets that I welded to the chassis, allowing about .75 of adjustability. Did you see the steel strips I bent to conform to the under side of the fender lip? To thus strip I welded an angle bracket with a single 1\4-20 x 1" bolt which connects my fender to the chassis bracket. I have two such connections per fender. This makes the body panels very quick and easy to remove and reinstall.
    Lance started working on the rear body.
    Here is some of Lance's work on the license plate mounting.
    Feb 2013
    Copperas Cove, Texas
    What modifications were required in order to get that gas tank to fit?
    -Jason
    Sep 2015
    Hamersville, Ohio
    Quote Originally Posted by EODTech87 View Post
    No mods necessary. I designed it to fit between frame members. Its also notched in the rear to allow for brake master cylinder clearance. Because of the triangular shape,fuel slosh is minimized. I did however make a riser for the filler cap to raise it above the frame members to facilitate fueling.
    Nepa
    whos frenched license plate kit is that?
    Sep 2015
    Hamersville, Ohio
    Quote Originally Posted by Samiam1017 View Post
    Superior Glass Works. $27 plus shipping. You will receive only the box. I've added the flange myself. When finished there will be a piece of 1\8" th plexiglass to cover the box. It will be flush with the rear panel.
    Feb 2013
    How much did it cost for them to build it and are you willing to share the data so if anyone wants to order one we can?
    -Jason
    Sep 2015
    Hamersville, Ohio
    Sure I'll share it with you. Boyds should have it on file tho. You really should look it over very close because I designed it for my application. Will wood brake pedals, plus I've redesigned my front radiator framework and am not using the supplied shifter cables. This all makes a difference. Pm me your email address and I'll send out a jpeg of my drawing. You can compare and modify where necessary.
    Jan 2016
    Subscribed, want to see the evolution.
    as you did the hood reinforcement how did you make sure you reinforced the hood is in the proper position? So you don't end up with a reinforced hood which is twisted or bent?
    Sep 2015
    Hamersville, Ohio
    Quote Originally Posted by bzoli View Post
    When you cut the grooves in the wood, this will allow them to conform to the hood curvature. Before filling saw cuts with epoxy, find a large cardboard box and lay it on its side. Push on the large flat until it has a slight dish. This will cradle the hood when you lay it on top of the box. Once the epoxy is put in the saw cuts, this will lock the hood into its natural contours. After the saw cut epoxy cures, it should have enough torsional rigidity to resist warping until the glass work is finished.
