Thanks Thanks:  8
Likes Likes:  44
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 241 to 280 of 320
Thread: RR20AC Build Thread
  1. #241
    RR20AC's Avatar
    Puyallup/WA
    Bad news today. One of the first and best Cobra drivers had to shut the doors to the racing school. Hope those instructors can find another place quickly. Here’s a longer version of my time there. https://youtu.be/7bKVHCt7FZ0
    20th Anniversary MK4 Roadster, #8752, 18 of 20, Delivered 12/03/15, 1st Start 01/28/2017, off to paint 4/13/2017, Forte 351w/ Holley EFI, Forte throttle linkage, TKO 600/Forte Hyd. Clutch, UniSteer Electra Steering, RT's turn Signals, many Breeze parts, Paint by the Jeff Miller. Finished on 10/08/2017. 500 mile inspection on 10/21/2017, 3000 mile inspection on 1/14/19.
  2. #242
    Chino Valley, Arizona
    That’s a shame!
  3. #243
    Central Lake, MI
    Really like you solution for the heater while still having a glove box (post #10). What are the dimensions of the extended box you built? how did you determine where to cut the opening in the firewall? Did you end up needing to build another box around the blower and run a hose to capture fresh air from the cockpit? I am waiting on delivery so some of this may be more clear once I see it in person but trying to organize all my thoughts on enhancements like this. Thanks in advance!
  4. #244
    RR20AC's Avatar
    Puyallup/WA
    I probably would build a box over the blower if I get a top. I feel there is no need with an open cockpit. The box has to be 2.5”s deep and the other dimensions are just enough for the core to fit inside. I got lucky with placement and only needed to groove the corner for the wiper tube to go by.
  5. #245
    Senior Member Pat427's Avatar
    New Braunfels, TX
    Congrats!
  6. #246
    Senior Member SSNK4US's Avatar
    Bakersfield, CA
    OMG!!! Seriously?? (sorry a little late) that is so sad!!!! I’ve been through a few of his courses and have had the privilege of actually having Bob for an instructor. Total class act...so very sad to hear of it’s closing
    Build thread
  7. #247
    RR20AC's Avatar
    Puyallup/WA
    3000 mile oil change and inspection done. A few added upgrades too. I added some new headlights that have the option of a running light inside and upgraded bulbs. Needed to rework these after installation as the manufacturing oils inside smoked the glass after first on. My oil pan and bell housing have always concerned me also, as they both were about 3/4 of an inch below the frame rails. Trimmed the housing and the 7 1/2 inch Milodon pan is now installed. Fel Pro has a product called SnapUps that made installation easy under the car. Watched several youtube videos on oil pan installs and the engine were all upside down. Not as easy under the car. SnapUps helped hold and line everything up while installing.
    Here's a couple of pictures.
  8. Likes Straversi liked this post
  9. #248
    RR20AC's Avatar
    Puyallup/WA
    Quick test drive today in fantastic weather. Wife even went. I guess the car is ready for summer.
  10. Likes cgundermann, Paul2STL liked this post
  11. #249
    BadAsp427's Avatar
    Greeneville, TN
    It looks sooooo good.... I'm so excited to be getting another 20th Anniversary Roadster on the road.... Tell me, what color red is that? Thanks...
  12. #250
    RR20AC's Avatar
    Puyallup/WA
    Nissan plasma red per da Bat
  13. #251
    Senior Member Paul2STL's Avatar
    Nov 2012
    Tacoma, WA
    Looking good Jim!
    MKIV #9122 Ordered kit 5/24/17 received kit 8/11/17 MK4 Base kit +,First Start 4/7/18, First Go-Cart 4/22/18, In gelcoat, licensed and driving 8/11/18. Coyote gen2, T-56, 2015 IRS 3.31, 17" Halibrand replicas w/Nitto NT555 G2, Withby Motorcars power brake kit W/Wilwood pedals, 04 Cobra front brakes, 15 Mustang rear brakes with mods, power steering. Paint Jeff Miller Da Bat, Lexus Spectra Blue Mica W/Toyota Silver Sky Metallic strips. Build thread: http://thefactoryfiveforum.com/showt...Paul2STL-Build
  14. #252
    RR20AC's Avatar
    Puyallup/WA
    Waiting for the weather
  15. Likes cgundermann liked this post
  16. #253
    RR20AC's Avatar
    Puyallup/WA
    Weather is getting better. Sunday cruise with a new gopro mount. Getting ready for track day on April 6th. Works well and you can't even see the mount. https://youtu.be/DUPtHN_vhac
  17. Likes WIS89 liked this post
  18. #254
    That is a pretty cool vantage point! Looking forward to some track day videos.
  19. #255
    Jan 2019
    I got my complete kit plus coyote and tko600 a few weeks ago. I have the 18x9s and 18x11s whats the best tire size?
  20. #256
    RR20AC's Avatar
    Puyallup/WA
    Front 255/35/ZR18
    Rear 315/30/ZR18
    I went with Toyo. Work really well. Soft. Lots of traction. Down side is they say they last about 5000 Miles and are more expensive.
  21. #257
    RR20AC's Avatar
    Puyallup/WA
    Went to a local shop today as a preview to a Hooked on driving event at the Ridge Motor park in Shelton. Racer on Rails. Awesome guys there and glad to help everyone get going in driving fast on the track. Twin brothers that race BMW's. They also are into full blown simulators and practice daily. The sims were very advanced and they have their cars loaded so they control just like on the track. Paul and I drove the cobras up and had a great time as the weather is fabulous right now. My numbers are on my car and I did a complete tech inspection for the track. I'll pull it up there next Saturday but the weather forecast says rain, rain and more rain. Here 's some pics before I loaded it on the trailer. I did do a 360 video but it take time to edit and I'll get it done later. jim
    P.S Also borrowed some Scales from Paul and corner weighted my car. Was very close so didn't have to adjust but the total weight was 2430 lbs empty.
  22. Likes Boydster, Mark Eaton liked this post
  23. #258
    Oct 2018
    central Iowa
    Looks like you have a 4 legged furry speed bump in the 5th pic. I bet he'll move when you fire that thing up.
  24. #259
    Looks great! Hope the weather forecast improves!
  25. #260
    RR20AC's Avatar
    Puyallup/WA
    Weather was Rainy. Hooked on driving had a great event though. Instruction was awesome and everyone showed up except one person. I'll do it again. Great way to experience time on the track.
  26. Likes RXBill liked this post
  27. #261
    Bothell, WA
    Pacfic NorthWET Crazy
    Jim,
    With those webbed feet from growing up in the NorthWET, I'll bet you were in your element. I on the other hand was chasing down a screaching sound coming from the bellhousing. Clutch ajustment fixed it. All better now !!
    As soon as I get more time behind the wheel (totally dependent on the weather gods) for some shakedown runs, I will be down to do a little cruising.
    Great picture.
    Bill
  28. Likes RR20AC liked this post
  29. #262
    RR20AC's Avatar
    Puyallup/WA
    Hi Bill, Did a little cruising today. Spring is fantastic here when the weather cooperates. Yards all done and I'm up for a cruise. Just let me know. There is an event coming up end of the month at Pacific Raceways in Kent. It is SOVREN Vintage racing. Would be fun to have a cruise up there with all the cobras to watch Karen Salvaggio run her coupe. Here's a few pics of the weather last weekend and today in the yard....
  30. #263
    Nov 2012
    Tacoma, WA
    Nice pictures Jim and that FFR sticker on your trailer is pretty cool! Funny thing is I was off today working on the yard, guess I should of sent you a text.
  31. #264
    RR20AC's Avatar
    Puyallup/WA
    Shoot could have been fun, Next time. Can't remember where I got that sticker. Oh yeh. It was from Paul.
  32. #265
    RR20AC's Avatar
    Puyallup/WA
    My Buddy Paul2STL got some vintage decals for his car and thought I would give them a try. Got them today and put them on before going on a quick cruise for a bite to eat tonight. I think I like the look.
  33. Likes cgundermann liked this post
  34. #266
    RR20AC's Avatar
    Puyallup/WA
    Paul looking at the pic now I guess I lost one already. I really liked that koni decal too.
  35. Likes cgundermann liked this post
  36. #267
    Decals look great. Really compliment your look.
  37. #268
    RR20AC's Avatar
    Puyallup/WA
    Thanks Scott
  38. #269
    RR20AC's Avatar
    Puyallup/WA
    Rode up to Pacific Raceways with my friend Paul in our cars on Sunday. Mark a future builder also rode along with us. He's talking of getting his kit in a couple of weeks as it is now done at the factory. SOVREN vintage racing had there first event of the year and there were 3 Factory Five Coupes running. Got to meet Karen Salvaggio and her Coupe she has been running for 3 years. Fantastic time with watching the cars going all out around the track. Thanks Karen for the time spent telling us about the sport. Truly an inspiration.
    On another note, My friends noticed at WOT my car had a puff of smoke out the passenger side pipe. I pulled the plugs and determined the #7 cylinder is oil fouled. I'm thinking a valve guide is leaking. Guess I need to take off that head now. Busy times ahead. Just don't know when I will get to it.
  39. Likes Straversi liked this post
  40. #270
    Senior Member q4stix's Avatar
    Seattle, WA
    Wow, wish I would have been able to join you! Thanks for sharing!
    Gen 3 Type 65 Coupe builder
  41. #271
    RR20AC's Avatar
    Puyallup/WA
    Next two races are on Spokane Festival of Speed
    June 8-9, 2019 | Spokane County Raceway
    Test-n-Tune Friday
    and then Pacific Northwest Historics
    July 5-7, 2019 | Pacific Raceways
    Karen said she goes to them all and the other coupe driver who is from Montana should be there too. He started his build in November and looks excellent.
  42. #272
    "The I.E." SoCal
    Quote Originally Posted by RR20AC View Post
    More likely a valve stem seal. I'd replace that first before removing the intake and the head.
    __________________________
  43. #273
    RR20AC's Avatar
    Puyallup/WA
    Thanks Frank. Guess Forte said that to in so many words but I misunderstood. Thought I had to get the valve out but after watching several YouTube videos I see it's much less time consuming P.S Karen asked if I knew you and I said yes he took us on an awesome cobra trip up in the hills when at Huntington Beach last year.
  44. Thanks frankeeski thanked for this post
  45. #274
    RR20AC's Avatar
    Puyallup/WA
    Well, replaced the valve seal and said to myself these new seals are more robust. So I replaced them all. Now looking at adjusting the valves and there are at least 5 different ways to adjust the valves and not sure which way to go. Any recommendations on a 351w 427 on adjustment.
  46. #275
    Assuming you have hydraulic lifters. If solids, ignore this response. On my two SBF builds, I followed the COMP Cam instructions. As each rocker is adjusted, you have to get the cam at the proper location so it's not pushing on that lifter. Do so by turning the crankshaft with a large socket wrench at the balancer, noting the rocker arm movement as it's going around. Set intake when exhaust just begins to move upward, set exhaust when intake opens and moves to nearly closed. Then turn the adjuster until there's zero lash in the pushrod. The usual way is to turn the pushrod back and forth between your finger and thumb as you turn the adjuster until you feel just the slightest drag meaning it's at zero. Then one-half turn (.030 +/- .010) on polylock down and lock. The main variation you'll see in my experience is how much to turn them down. Some will way 3/4 turn, etc. These were the instructions I followed. I think the main point is the hydraulic lifter has to be somewhere in the middle of it's travel.
  47. #276
    RR20AC's Avatar
    Puyallup/WA
    Thanks Paul. I'll take a look at that info. Love to figure things out and this site has the best information on what make an engine work. I've adjusted solids before and all worked out. just trying to wrap my head around how hydraulics work. Jim
  48. #277
    Jun 2018
    North Vancouver, BC, Canada
    I found this video interesting and helpful. Another approach that's a bit different than the need to locate specific spots on the cam and having keep track of what you've done and haven't. No matter whether you take that approach or not, the big take away I got from this video was do not pump up your hydraulic lifter with oil before adjusting.
    https://www.youtube.com/watch?v=5EGlb_VpTAw&t=188s
    Gen 1 '33 Hot Rod #1104
  49. #278
    Senior Member Gromit's Avatar
    Mass, North of Boston
    I would contact Forte, ask what cam is installed and see if you can find the install / spec sheet. Different cams and manufacturers can have different pre load specifications. the process of getting the lifter on the cam base as Paul described is dead on. what can be variable is how much pre load they use.
    Chris AKA Gromit
  50. #279
    RR20AC's Avatar
    Puyallup/WA
    Those are all the variables that had me scratching my head. Thanks guys.
  51. #280
    RR20AC's Avatar
    Puyallup/WA
    Finally got to working on my engine after a busy week at work and trying to figure out the proper way to adjust my valves. Thanks Edwardb for the information on the comp Cam site. Very in depth. I also called Forte and he hooked me up with Jim his mechanic. Jim explained I did have hydraulic lifters and explained how many turns are needed after zero lash according to the stud size of the rocker due to the threads will make the lash more or less. I actually took off the distributor cap and marked each top dead center for each cylinder on the distributor and the process was easy to do. Seems to run smoother now as the # 7 plug is not fouled with oil any more. https://youtu.be/3ESlwtYihPI
  52. Likes Boydster, cgundermann liked this post
