Group buy for a transmission mounted bell crank shifter. Shifter is machined from 6061-T6 aluminum with a double sealed ball bearing for smooth crank motion.
Even if you already expressed interest in the feeler thread, please reiterate your direct interest in this group buy thread. If you wish to be included but only after a certain number of buyers are in, please indicate as such (for example, you'd like to be in, but only if we reach the 10 participant price level).
Works with:
Subaru 5 Speed transmission
Plastic FFR shifter
Metal FFR shifter
MR2 Shifter
Not compatible with:
6 Speed transmission
VCP Shifter
What it does:
Allows you to reduce the number of bends in the shifter for smoother and more direct feel
When used with an MR2 shifter the cable length can be reduced 7 feet (shorter length cables not supplied as part of kit)
The arm mounted to the input shaft is mounted further inboard for improved clearance with the rear bumper (almost 1" of the shaft would actually be cut off if desired)
Looks pretty fancy. In an open rear bumper setup it is visible from the outside.
# of people: Cost
5: $365
10: $280
15: $255
20: $250
What you get:
Base plate
Cable mounting plate
Bell crank with pressed in bearing
Selector arm (mounts to transmission input shaft)
Red anodized aluminum rod ends
Aluminum connecting rods
Aluminum Spacer for base plate
Stainless spacer for bearing
Stainless Hardware and nuts
50% deposit due when group buy closes
A few cell phone shots showing the assembly, an exploded view, and installed on an 818.
Assembly:
Exploded view. Hopefully this image shows how much work and how many pieces are put together to make this setup:
Angled view on transmission:
Group Buy:
1: Red Fogo (@10)
2: Mitch Wright (@10)
3: Flamshackle
4: The Furnace
5: Garden (@10)
6: Newkitguy
7: Canadian818
8: Blwalker105
9: Mulry (@10)
10: 65 Cobra Dude
11: Stebru
12: Nor cal Ray
13: Long Island WRX
14: Billjr212 (@15)
15: Albertan
16: DSR-3
17: FFR ADV
18: Mikeb75
19: Flynntuna
20: Hobby Racer
21: Craigfree
22: Ben1272
23: Will D
24: Todd Budde
25: Samiam1017
26: Lifunfe
27: Solidworks-Mike
28: SpeedyG
29: Stickshift 84
30: ewingate
31: phillig
32: wirenut
33: bbjones
