Results 1 to 25 of 25
Thread: Wire terminals
    Wire terminals
    Does anyone have any idea where I can find some wire terminals? I need 4 female ecu terminals and 4 femal terminals for the bulk engine harness. I can't seem to find any real info on where to buy them or what size they really even are.
    Note: Found the answer see later posts.
    This is for 02-05 wiring harness.
    Quebec, Canada
    I was wondering the same...
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    A few options:
    1. Pull some terminals from the ECU you do not need then move them over. To do this you need to pry up a little locking tab. It's very small and hard to figure out if you haven't done it before. PM me if you need help with that.
    2. Contact Brian at iWire and see if he has some and will sell them
    3. Call the dealer. For some reason, dealers are a real crap shoot when it comes to electric terminals. It isn't something they sell much of so a lot of times the part isn't even available, or they only have it as part of a "wiring repair kit which is extremely expensive and something only a shop would purchase .
    4. Junk yard
    I want to make my own 4 wires for avcs sensors so I need new terminals cause I want it to be a single wire no splice. I have a terminal tool and have mastered it well .
    Jan 2012
    You need to be carefull with ecu terminals they are a pita, trust me I've crimped so many of them and avcs is always fun to get working. Give Brian at iWire a call tell him Robert told you to call.
    iWire's Avatar
    Lake Forest, CA
    Hey guys,
    Unfortunately we are not to sell the ECU pins per the agreement we have with the company that sells them to us. I believe you can get free samples from the manufacturer (Touchstone may have done this?) which would probably be enough for most projects.
    -Brian
    UPDATE THIS IS NO LONGER THE CASE - WE SELL MOST PINS/CONNECTORS/ETC - http://www.iwireservices.com/online-store
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    [email protected]
    Sad day but I may be finding what we need guys! Been looking all weekend and had summed it down to a few things I still need to find the ECU connectors. But I'm going to test a few connectors and look more in depth to find some part numbers If the have them... Post what ends up working once I find what we actually need.
    http://www.corsa-technic.com/item.php?item_id=673 -->> this looks like the connector found in the engine bay minuse a few pins that the AVCS sensors wires are in. So I think the pins listed in this link is what we would need.
    Pins needed for female engine harness are--> Sumitomo DL-SL-HX090-S
    http://www.corsa-technic.com/item.ph...ategory_id=105 ---> looks close to the body harness to the engine harness. Not the same, So I think the pins listed in this link is what we would need.
    ECUpins ---> http://www.onlinecomponents.com/te-c...tml?p=10358112
    Note: Speculation post I will confirm the right numbers once I get my order in and get things tested. I think I can at least narrow things down after I measure.
    Mar 2013
    Maybe these guys can help you out. On the plus side for you, the American dollar is very strong compared to the Canadian dollar so it'll likely end up being fairly inexpensive for you
    https://www.facebook.com/n.v.auto.pe...type=3&theater
    Quote Originally Posted by theburner9 View Post
    I want to know more about the terminals though. I just think its silly to charge $200 for 4 wires with .25cent connectors on them. Maybe if it was wired for me it would be worth it, but I can read the wiring diagrams just fine myself and have done so already, I rather not give $200 for 4 wires.
    Mar 2013
    Yikes! I didn't see the price! OUCH!!
    So the ecu pins say AMP 1 on them so its a tyco/amp/TE terminal it should be 316836-1 honda guys also use them. http://www.onlinecomponents.com/te-c...tml?p=10358112
    After knowing what part number to search this thread came up in Google http://thefactoryfiveforum.com/showt...ng-pin-removal
    I got my order in for the ecu and the engine connectors. I will confirm here once I get them and can confirm its the right number needed. I had to order 100pins for the ECU and 100pins for the Engine harness connectors, so if you need any let me know I will have plenty. Im 99% sure the engine harness connectors are correct and about 80% sure on the ECU so I will confirm in a week or so since some are coming from Japan. I rather order plenty so I can get other people pins when needed.
    In summery
    ECU = Tyco/AMP
    Engine = Sumitomo
    Senior Member Loring's Avatar
    Nov 2015
    Lakeland, FL
    Quote Originally Posted by redfogo View Post
    In summery
    ECU = Tyco/AMP
    Engine = Sumitomo
    Glad you got it all sorted. I was just going to suggest that you go to a GM dealer and ask to look through their terminal box. They're supposed to have on hand then entire kit with all terminals, with everything from Delphi, to Tyco, Sumitomo, Yazaki, etc.
    Just match them up and write down the part number. Sometimes they'll sell them, other times they're already paid for by the service department under 'shop supplies'. Depends on the dealer.
    818C | Kit delivery: 3/19/16 | Status: Powertrain installed
    Daily: 2014 CTS-V - Fat and slow
    Just as an update the terminals I ordered were correct. So if anyone needs ECU or engine pins lets me know I have plenty, but if you want to order your own use the following numbers. Most every engine connector on the harness is made by sumitomo. So if you need the actually engine connector look through their catalog. I see sites selling stuff as "subaru specific pins and connectors straight from japan" . They are charging as much as $5 a pin and $20 a connector. You can get them much cheaper if you find the part number and not look at it as Subaru specific.
    ECU--316836-1 amp
    Engine harness-- small HX090 sumitomo
    ECU--316836-1 amp
    This is great. On my first 818 I opened the ECU and soldered wires to the back side of the connector.
    Do you have or know where to get the tool for removing pins from the ECU connectors.
    There is 2 different size pins in my ECU and you only have one number?
    Glad you asked because I forgot to post. This is for 02-05 wiring harness. I can try to help you track down what you need though if needed. Didn't take too long. As for pin extractors I got them from napa links are below. They work on every connector in my harness.
    http://www.napaonline.com/p/NW_725169 <-- Larger extractor not really needed only used on the very larger connectors.
    http://www.napaonline.com/p/NW_725168 <--- Smaller style worked on every pin from the ECU to ABS to larger style. If you only buy one buy this one. Best tool I could find much better then the multi pin tools has awesome leverage length and very thin.
    Redfogo
    Is this the connector and pins you are talking about?
    Redfogo
    Those do look like AMP/TYCO connectors. I have 5 connectors though not 4. So Its not the same design. Pins look the same as what I have but without close up pictures of the pins I can't help to much. If you send me some close ups I can help better
    Senior Member TouchStone's Avatar
    Sep 2014
    Dallas, TX
    Quote Originally Posted by iWire View Post
    Hey guys,
    -Brian
    I did indeed do this. They were exact replacements and the datasheets gave part numbers for the crimp pins, bought from (DigiKey $10-20 for a hundred or so)
    818S Chassis #288 2.5L 323hp
    Ordered: 9/19/14 Received Kit: 11/2/14 First Start: 5/31/15 First Drive: 6/7/15 Registered: 3/10/2016 Completed: 2/10/2017
    Status: Complete Build Thread Sold 9/22/2017
    joshuajach.com
    Sep 2014
    Dallas, TX
    That's a little scary...
    There is a big tab on the ECU connector that needs to be pried up before you can remove the pins. Then use a tool, pick, flatten end of paper clip to remove each pin.
    joshuajach.com
    Quote Originally Posted by TouchStone View Post
    Touchstone,
    Opening up the ECU box was not scary at all. Four small screws.
    I FEEL PRETTY STUPID RIGHT NOW.
    Do you know how many hours I spent looking for pins and removal tools. Then hours trying to get the pins out without success.
    NO ONE TOLD ME ABOUT THE SECRET TRAP DOOR LATCH.
    I even think I talked to Brian about removing the pins.
    Thanks Touchstone
    Touchstone,
    Thanks Touchstone
    Ohh those little doors are a pain when you don't know what they are for or how they work! The 1st time I took one out when I was making a harness for my MR2 it ended up broken... Learned my lesson, on the 818 wiring was much more easy and not full of broken wires since I knew what I was doing yay! I have this all included in my wiring guide I plan to publish on my site and build thread once I can confirm its all working 100%.
    Sep 2014
    Dallas, TX
    I meant soldering to the back of the ecu connector. I have multiple issues with it relating to shorts, joint quality, wire strain relief, routing, ease of replacing the ecu, ect. But if your confident in your wiring and soldering skills and they look like this not this then you'll probably be fine.
    joshuajach.com
    Senior Member fastzrex's Avatar
    Oklahoma City
    Thanks, redfogo, for your research and time. Made the harness much easier to navigate!
    ~ Mark
    818C S/N 429ES: Start Date 1 September 2016
    2001 NB Miata LS3 V8 440 rwhp
    2004 Miata MazdaSpeed Factory Turbo
    Mar 2014
    Oakley, CA
    This place is a tremendous resource:
    http://www.cycleterminal.com/
    He's got his site sort of taken down for the holidays, but definitely check it out when he re-opens.
    Glad it helped if you guys need any terminals PM me I have a good amount of extras
