Page 4 of 6 FirstFirst ... 23456 LastLast
Results 121 to 160 of 203
Thread: MK4 #8951 Build
  1. #121
    Senior Member lahrs37's Avatar
    Jul 2014
    Philadelphia
    Quote Originally Posted by RickP View Post
    I think I heard the pop your referring too in the above vid. Right when before you said "backfire". Where do you have your O2 sensor located? I originally located mine in the header which turned out to be a big mistake. After relocating to the side pipe collector, my motor smoothed right out.
    Interesting. I do have the o2 sensor in my header. What engine are you running? I go-karted today and there were no pops or crackles. https://www.youtube.com/watch?v=drbqYCAAKQQ
    On a separate note I am leaking power steering fluid and oil. I will address both of those leaks before I run it again.
    5.0 HO from a '93 Mustang, SVE heads, Trickflow stage 1 cam, Trickflow Street Burner intake manifold, T-5 w/mid shift, IRS
    Delivery 9-10-16, First Start 12-28-16, First Go-Kart 2-18-17
    Build thread: http://thefactoryfiveforum.com/showt...MK4-8951-Build
  2. #122
    Senior Member RickP's Avatar
    Boyertown, PA
    I think I have my answer to where your O2 sensor is. 3:21 into this vid I see the hole for your O2 sensor in your header. I had mine located in the exact same location. Almost identical to where yours is and my motor would just not run right. I'm running a FITech EFI but the principal is the same. Your collecting info from one exhaust port. I was advised to move mine just behind the collector on the side pipe (still not sure if it will interfere with the body installed) but, after doing so, all my engine tuning issues went away. Like as in night and day.
  3. #123
    Jul 2014
    Philadelphia
    That is really good to know! I have ordered a pair of Gas-n pipes. When I get them I will look into welding bungs into them. Maybe I will wait until the body is on so I don't run into interference issues like you mentioned you are concerned about.
  4. #124
    Boyertown, PA
    Quote Originally Posted by lahrs37 View Post
    Based on your go-kart vid (congrats BTW), sounds you have it running great. If its running right, leave it be. Back firing on an EFI motor usually boils down to the O2 sensor. Confusion on the air/fuel mix. but sounds as if your setup is reading correctly. I didn't hear any popping in the vid.
    I have a 302 pulled from an 87 5.0. Instead of the stock EFI mumbo jumbo I am running a FItech efi. My O2 sensor was in the same place as you have yours currently. It always ran rich and I couldnt even get a tune on it. It would run one minute, and not the next. Only way I could keep it running was to put my foot into it. Now I have it plugged up and the sensor is at the collector. Runs and idles perfect.
  5. #125
    Boyertown, PA
    I'm going to attempt body fitment next weekend. I'm really hoping I have the sensor angled right. With all the trials and tribulations you have been through as of late, I bet that go-kart ride was like wooooo hoooo.
    P.S. I had a number of leaks to overcome.
  6. #126
    Jul 2014
    Philadelphia
    My 302 is from a 93, but I opted to stick with the stock fuel injection setup. If I start running into problems in the future I will definitely keep the o2 location in mind.
  7. #127
    Jul 2014
    Philadelphia
    I was also thinking I might toss on the body for a bit so I can bolt up my high-back seats in the correct position. And yes the ride was freaking sweet!
  8. #128
    Boyertown, PA
    I admire your tenacity. The 5.0 stock setup coupled with the OEM harness is a lot to overcome/understand. The motor set-back you had can easily take the wind out of your sails. Makes that first go-kart ride all the better....
    keep the video's coming. Love seeing your progress.
  9. #129
    Jul 2014
    Philadelphia
    Thanks for the kind words! To be fair, I am using the Ron Francis chassis harness and their front harness which makes things a lot easier. My tenacity has basically been a byproduct of my stupidity. Either way, I will definitely keep the videos coming!
  10. #130
    Jul 2014
    Philadelphia
    A little Go-kart debriefing and a look ahead to what is next: https://www.youtube.com/watch?v=KbJ4vrX9aGo
  11. #131
    " My tenacity has basically been a byproduct of my stupidity."
    This is one of the best lines I have read on here. I've certainly had the same issues but haven't been able to put it into words as eloquently! ha
    Enjoyed the latest video.
    Couple things on the seats and heaters.
    I think I read about every thread possible on the kirkeys. Keep in mind you can also bend that outside shoulder bolster in a little bit to help with body clearance. That may be preferable to having the seat angled.
    I used some mounts that attach to the side of the seats that allow you to position them with a little recline. I am very glad I used those. Purchased from Summit.
    I had the wiring portion of the seat heaters come out the rear of the seat and I riveted the harness to the seat back and then ran the wires into the transmission tunnel behind the seats. It hides the wires nicely.
  12. #132
    Jul 2014
    Philadelphia
    That is some super helpful info. Thanks!
  13. #133
    Jul 2014
    Philadelphia
    Quick update: https://www.youtube.com/watch?v=_QQ9NWyxaPM I am rethinking the way I am mounting the seats now that I read the previous comment...
  14. #134
    Hey Laurence,
    It really looks like you are making good headway.
    Nice to see that you conquered that engine mishap.
    Keep It Up Bubba!
    Jul 2014
    Philadelphia
    Hey Laurence,
    Keep It Up Bubba!
    Thanks Steve!
  16. #136
    Jul 2014
    Philadelphia
    Here is a quick video from today. I have the body on to get the right angle for the seats and couldn't resist popping out for a quick little ride. Also new are the Gas-N pipes which sound stellar. I have been tracking down leaks and slowly making this thing more solid. On the list is my loud-*** power steering pump! https://www.youtube.com/watch?v=DlFZnoyCwd0
  17. #137
    Fayetteville WV
    lahrs37,
    Car sounds awesome! Are you sure the power steering fluid is full? Sounds like a typical Ford whine when it's low on fluid.
    Len
    1972 Corvette Stingray 350 c.i. Manual Steering & Brakes
    2003 H-D Softail Deuce 88 c.i. TwinCam
    Gen 3 Coupe Dreamer
  18. #138
    Jul 2014
    Philadelphia
    Quote Originally Posted by Vette1972 View Post
    lahrs37,
    Len
    I had a leak in on the high pressure side. I fixed it and topped off the fluid, but it definitely sounds like air got into the system.
  19. #139
    Jul 2014
    Philadelphia
    I have been in the doldrums of my build for a little while, but I have been still working!
    Video update: https://www.youtube.com/watch?v=kLMdiDd8qhw
    Dashboard and shifter:
  20. #140
    Breezed through your video and have a couple of comments.
    1) The sidepipe cutouts get addressed during the bodywork phase in conjunction with the actual fitting of the pipes, final positioning of the body and installation of splash panels. they always need to be massaged and enlarged.
    2) There are other sources for throttle cable (Lokar, etc). No matter what one you ultimately use PLEASE add a second return spring. The light spring on the throttle body is not designed or intended to be used as as a positive return.
    3) The cooling fan is a high amperage draw and needs to switched through a relay with a 30 amp fuse on the output side (you will use the lower amperage fuse on the switch side).
    You're getting there---carry on!
    Jul 2014
    Philadelphia
    1. Good to know!
    2. Do you have a link to a return spring setup? I was really surprised that there wasn't one in the kit. I definitely would like to run one.
    3. That makes sense. I will look more closely at that and route it appropriately.
  22. #142
    The veneer on the dash looks really cool. That looks like a pretty great shop your father in law has!
  23. #143
    Senior Member Jdav's Avatar
    ATL GA
    I assume I don't need my full kit provided accelerator cable since I'm running a coyote (correct me if I'm wrong coyote guys). If that's the case I can send you mine if you cover shipping
  24. #144
    Jul 2014
    Philadelphia
    Quote Originally Posted by Jdav View Post
    That would be awesome! I will PM you.
  25. #145
    Jul 2014
    Philadelphia
  26. #146
    Jul 2014
    Philadelphia
    Video update re: interior. https://www.youtube.com/watch?v=skU6TGCcNG0
  27. #147
    Good video. A couple things:
    1. The seat heater foam cut away pretty much stinks as you mentioned. I couldn't figure out an easier way!
    2. The odd shaped carpet pieces you asked about - you need to wait until the body is installed and you install the aluminum pieces that go between the door opening on the frame and the body. They cover that area.
    3. I went to Home Depot and got gray indoor/outdoor carpet for my trunk. Thinner than what you used, cheap and easy to install. Worked great. Pics in my build thread. Index in post 1 should tell you were to look if you are interested.
  28. #148
    Jul 2014
    Philadelphia
    1. Darn!
    2. Ah that makes sense. I was kinda thinking that might be the case.
    3. Awesome! Thanks​ for the tip. I will check that out.
    I have a terrible habit of jumping into something and learning by making mistakes. When I try to slow down and read all of the information that is here I find myself not getting into the garage. I am working on it though!
  29. #149
    Jul 2014
    Philadelphia
  30. #150
    Laurence,
    If you booger up your dash pad and need a new one I've got an original one that I can send you.
    Let me know if you want me to send it to you.
    You just have to pay for the postage.
    Good Luck!
    Jul 2014
    Philadelphia
    Laurence,
    Good Luck!
    Thanks Steve!
    Since I am going to eventually install the veneered one my father in law is making I don't mind messing this one up a little. Now, if you happen to have transmission tunnel carpet... lol
  32. #152
    Thanks Steve!
    Too Bad & So Sad That I Don't!
    Have A Great Day!
  33. #153
    Jul 2014
    Philadelphia
    Have A Great Day!
    You too!
  34. #154
    Boyertown, PA
    Thanks Steve!
    If your looking for a tranny cover carpet piece, your certainly welcome to mine. I'm planning to cover mine with a different material. Maybe we can meet halfway between Philly and B-town somewhere. Shoot me a PM if you want an easy snag.
    Rick
  35. #155
    Jul 2014
    Philadelphia
    Rick
  36. #156
    Jul 2014
    Philadelphia
    Video update: https://www.youtube.com/watch?v=h7TOShNamiM&t=25s
    Now that the weather has turned I am all revved up again!
  37. #157
    Jul 2014
    Philadelphia
    New video! i am getting better at this...
    https://www.youtube.com/watch?v=dv5EDiyInik
  38. #158
    Another entertaining video.
    My foam residue on the seat looks just like yours in the rough areas. Once its put all back together it works great and you cant feel any irregularity in the seating surface. I personally would not spend to much extra time getting all the fine scraps off.
    I am excited to see this finished dash!
  39. #159
    Lawrence,
    If you need an extra dash cover (FFR Orgininal) I can send you mine since I didn't use it.
    Just P/M me your address and we can settle up on shipping later.
    Also, you really need to try doing stand up.
    Whit Is Your Strong Point!
    Boyertown, PA
    Ah ha! Another video. I'm happy to know your back at. I also picked up that you have the RT turn signals. I wired the stalk button as a flash to pass and if the headlights are on, works as brights. Really integrates well with the FFR light switch.
    Seats are coming along I see. Keep those videos coming.
