Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
Thread: Valin's Roadster Build Thread in Pictures # 8632
    Senior Member stack's Avatar
    Macedon, NY
    beautiful car
    stack
    FFR MKI Roadster FFR2202K Built in 2000 sold
    FFR Hot Rod #39 under construction
    Valin's Custom Cars valin's Avatar
    Jan 2015
    Sudbury, Ontario
    Hi. Great looking build. I've lost track of the progress. My Coyote/MkIV is just down the road now in Espanola. I'll sneak out to the valley this spring with my Alberta plates for a visit. Every time I take it out it's like a car show at the gas station or the DQ. Haha...love it.
    We will have to get together for sure. A good friend of mine (Marc Morin) has a MKII. His is yellow with black stripes. He belonged to the Espanola car club before, so you may know him. We will have to plan a little cruise or 2
    Jan 2015
    Sudbury, Ontario
    It ought to be monster. The 598 I built for my boat made 800 HP at 6000 rpm using afr 335 heads and a slightly smaller hydraulic roller cam than yours. It did have a Dart tunnel ram with 4 2bbl efi throttle bodies that I made. And it would run wide open for hours on end. I would certainly expect your engine to make similar numbers. Not sure what effects the rod ratio will have on it though. They are going to dyno it for you, right?
    The motor ended up making about 722hp, and 687 ft. lbs. with my intake manifold, Q950 carb, and my air cleaner. It is a little lower than we had expected, but it's a very conservative dyno, and it's still a tonne of power to have in a Cobra I love the torque curve (or basically flat line!)
    Jan 2015
    Sudbury, Ontario
    Thanks for the compliments guys! I appreciate it
    bobl's Avatar
    Spicewood, Texas
    That is some serious power. My car has a little over 500 and it's pretty impressive. I can't even imagine 200 more HP!
    Great looking car! IMO, something is choking your engine though, you should be making 75-100 more hp. Still plenty to put a big smile on your face.
    Jan 2015
    Sudbury, Ontario
    Quote Originally Posted by Plebeian View Post
    The motor made about 745hp with a slighly larger single plane intake, and 1250 Dominator on it. I don't think it's too far off what it should be making. Keep in mind that it's a Hydraulic Roller, not a solid roller. Shafiroff advertises their low deck 598 at 775hp with a solid roller, and a slightly higher compression ratio (10.5:1)
    Fantastic Job!
    FL
    Nice paint job. I like your variation on the traditional stripes.
    Jan 2015
    Sudbury, Ontario
    Hey guys. The Blueprint Engines 598ci big block is in and running. I have not driven the car yet, as our weather has been terrible this spring, and the roads are still pretty sandy. Just thought I would post up a few pictures of the new monster.
    Ryan Valin
    Valin's Custom Cars, Inc.
    [email protected]
    (705) 207-4297
    Jan 2015
    Sudbury, Ontario
    Ryan Valin
    [email protected]
    (705) 207-4297
    Jan 2015
    Sudbury, Ontario
    Ryan Valin
    [email protected]
    (705) 207-4297
    Jan 2015
    Sudbury, Ontario
    Ryan Valin
    [email protected]
    (705) 207-4297
    Jan 2015
    Sudbury, Ontario
    I still have a few things to finish up. With the raised exhaust ports on these heads, it has left me with one of the header tubes too close to #8 cylinder spark plug. So, I have ordered some header tubing and I will redo that single tube. I also have installed a power steering rack in the car, and ran into a conflict with the pump mounted reservoir. I now have to modify the pump and run a remote reservoir setup. Not a big deal, just a bit more time to get it finished. Soon it will be tearing up the tires
    Ryan Valin
    [email protected]
    (705) 207-4297
    Soy Ryan,
    Can I assume you kill knats with a baseball bat?
    Love That Kookie Kar!
    Darkside Time Two!
    Crazzzzzzzzy!
    Jan 2015
    Sudbury, Ontario
    Soy Ryan,
    Darkside Time Two!
    Crazzzzzzzzy!
    Haha! Anything less would be uncivilized
    Ryan Valin
    [email protected]
    (705) 207-4297
    Quote Originally Posted by valin View Post
    If you want to add a 6th gear, then contact Bill Boudreaux at:
    www.zfdoc.com
    He is the foremost authority on the ZF S6-40 6-speed transmission.
    Jan 2013
    Belleville, MI.
    I love this set up! Looks fantastic!
    Dido on the nasty spring weather. I drove my Coyote/MkIV from Espo to North Bay last Friday. I plan to keep it there. It was a top on drive, but even so.....SO much fun. Any predictions on how many sets of tires you'll go through this season with that monster under the hood?
    Great job on the car and one of the nicer build threads on this forum.
    Wow looks awesome. Please post some video of this thing running and in action when the time comes!
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Not big enough.
    Kyle
    Kearney Nebraska
    x2 on the video. Wicked car!
    Serial #9158
    Jan 2015
    Sudbury, Ontario
    I'll get some videos up for you guys shortly. A photographer friend of mine just bought a high quality drone. He wants to do some videos with the drone following the car down some twisty roads. Should be pretty cool!
    Ryan Valin
    [email protected]
    (705) 207-4297
    Jan 2015
    Sudbury, Ontario
    Thanks Dave. I appreciate it!
    As for the tires.....probably just one set It's just a grocery getter
    Ryan Valin
    [email protected]
    (705) 207-4297
