First Start
I will post again later with the weekly update. Without stringing this out. I got first start today and I am very excited.
I had a little trouble with the timing initially but I called BobL (another local forum member) and he walked me through it. Initially I had to work the throttle a little to keep it running. But after some inspection time (looking for leaks and other abnormalities) I set the timing and it runs a little better. Still not real smooth so I will have to do some research and fine tune it later. But here is the video.
https://youtu.be/81okBAQI0Gk
