I don't have any aftermarket AOS installed yet. The vents from the heads still run to the turbo inlet hose and that is all dry. All of the vacuum lines running to the intake manifold are dry as well. The one that was most suspect to me was the PVC valve. That runs to the turbo inlet hose and to the intake manifold. Hose to the intake manifold looked clean. I removed the hose from the PVC valve to the manifold and ran the engine for a few minutes just to see if the PVC valve would spit out any oil. I didn't see any. Again the amount of oil on the turbo exit is very excessive.
https://photos.app.goo.gl/F2rt6GmeuLsePspGA
I also opened up the oil filler cap while running the engine. I don't see any smoke coming out and it has a suck/blow action.
The smoke does not smell like coolant so I think it is now safe to say that it is oil so I don't think doing a cooling system pressure check is needed.
One last thing to note, I am using the crank case vent as it is designed for the 2.5 short block. I had the 2.0L valve covers modified to allow the crank case to vent to the valve covers.
