MKV, no clue. But the next big thing?:
https://thefactoryfiveforum.com/show...ics-NEW-COUPE-!
The coupe will never have a space frame due to the lack of a roof and the door openings.
I can't imaging any car that has more room for personalization than Factory Five. You bolt or rivet every part in to make your car, your way. If you think you want something different, integrate it. If you can't find it, make it. The chassis is mild steel so you can remove parts, fabricate your own replacement and weld that on. They'll probably sell you one without their chassis if you want to build your own, try that with one of their competitors.
Coupe 0652 408 Windsor 510 hp TKO600-68OD 3.73 Traction-lok A/C and heat, Guardsman Blue with White stripes picked up 9/14 first start 7/10/15 go kart 8/15/15 registered, painted (body-on) 11/12/16 inspected and on the road 4/20/17
