Thanks Thanks:  61
Likes Likes:  403
Page 4 of 27 FirstFirst ... 2345614 ... LastLast
Results 121 to 160 of 1072
Thread: John's EZ36R H6 818R Build
  1. #121
    Syracuse, NY
    Oooooh.... it's so pretty, can't wait to start it, can't wait to start it. I feel like a little kid
    MK3.1 Roadster completed 2011
  2. #122
    Very clever! Did you put a magnet anywhere else to sweep up debris?
  3. #123
    Syracuse, NY
    I did not put the magnet back in. There was no place to secure it and I did not want it floating around. As its a track car, I drain the fluid regularly and should notice any bits floating about.
  4. #124
    How did you plug/ vent the heads, I only see one coolant discharge?
    I see the expansion tank on the driver's side. I had a lot of pain venting both heads.
  5. #125
    Nepa
    did you block off any of the water lines? looks like you looped the heater hose? also what about the smog stuff what did you do there? thanks
  6. #126
    Syracuse, NY
    Quote Originally Posted by craigfree View Post
    In the pic above the head discharge on the passenger side is hidden below one of the frame braces. You can see it clearly in the pic below.
    There a a lot of good pics of the coolant tubes in this post.
  7. #127
    Syracuse, NY
    Quote Originally Posted by Samiam1017 View Post
    I blocked off the lines going to and from the throttle body. They are only needed to heat the intake charge during cold weather. I also blocked the line going to the factory oil / water sandwich plate cooler (I removed that cooler completely). I then connected the return port from the oil / water cooler to the return port on the bottom of the expansion tank (suction side).
    Initially I removed and plugged the heater hose lines. I then had to put them back and loop them when I discovered that they are needed for the thermostat to work correctly. There needs to be a hot coolant return path behind the thermostat so it senses the hot coolant and opens!
    I removed the all the smog stuff, EGR valve, drain valve, vapor canister, etc... I plugged the EGR hole in the intake manifold and the heads with block off plates.
  8. #128
    I wish you told me that two months ago, it took me so long to figure that out. I was chasing venting for months.
  9. #129
    Syracuse, NY
    I only stumbled across it in a nasioc thread I was reading recently and the light went off in my head. Glad I did not toss all that piping!
  10. #130
    San Diego Ca 92106
    I removed the all the smog stuff, EGR valve, drain valve, vapor canister, etc... I plugged the EGR hole in the intake manifold and the heads with block off plates.[/QUOTE]
    Are these the parts you eliminated?
  11. #131
    Syracuse, NY
    Yes, those can be eliminated so long as you block off the openings that are left over.
  12. #132
    Sgt.Gator's Avatar
    Bend, Oregon
    I hope you get on track soon, I want to see - hear this video!
    Owner: Colonel Red Racing
    818R ICSCC SPM
  13. #133
    Nepa
    John what three size masters did you go with for your wilwood pedal assembly?
  14. #134
    Syracuse, NY
    I went with the following:
    3/4" Front
    13/16" Rear
    3/4" Clutch
    But I am using a very different brake setup than most.
  15. #135
    Syracuse, NY
    Custom Headers Part 1
    I finally started welding the header tubes together. I needed to make 6 long "J" sections for my header design. I just got a TIG welder and my skills are less than professional. But the tubes are sealed and I'm pushing forward.
    IMG_20170926_164523-0.jpg IMG_20170926_164523-1.jpg IMG_20170926_164523-2.jpg
    To make the tubes look nicer, I ground the welds flush with the surrounding tubes.
    The headers are equal length. As you can see in the picture, I offset the tubes by the collector 1.5" compared to the flange plate for better clearance.
    Next I have to tack weld the collector and flange plate on and do some test fitting.
  16. #136
    San Diego Ca 92106
    Awesome!
  17. #137
    Wow this is going to be a work of art!
  18. #138
    Syracuse, NY
    Thank you. I'm hoping for good functionality, a nice appearance is a bonus.
    I plan to have them ceramic coated with Swain Tech White Lightning when they are done.
  19. #139
    Syracuse, NY
    Custom Headers Part 2
    Driver and passenger sides welded up.
    Here are some pics installed on the drivers side to check fitment.
    Here are some pics installed on the passenger side to check fitment.
  20. #140
    San Diego Ca 92106
    They look great! The passenger side brake line looks really close to the header. How much space is there between the header and that line?
  21. #141
    Syracuse, NY
    Yes, I plan on moving the brake lines to the side of the frame rail instead of on top like it is now. Figured I would wait till the headers are done in case I need to make other changes.
  22. #142
    Bowling Green, KY
    Looks like really nice solution, looking forward to the finished product.
  23. #143
    Nepa
    they look great!
  24. #144
    Every time I pull up this thread, I think that intake looks like a scorpion.
  25. #145
    Syracuse, NY
    Headers Are Done!
    Finished fabrication, still need to grind and polish the welds.
    Here are some pics of the last test fitting.
    I have ordered some hump vents for the exhaust exits.
  26. #146
    Nice work! That's going to sing.
    The H6 intake manifold looks like the face-sucker from Aliens.
  27. #147
    Can't wait to hear it!!
  28. #148
    south-central CT
    Purely for racing? Many of the tracks I frequent for track days, have sound limits. Any thoughts about mufflers?
  29. #149
    San Diego Ca 92106
    Looking great! If you get a chance, could you get a picture of the headers a little further back, with the perspective of say from the firewall to the axles?
  30. #150
    Sgt.Gator's Avatar
    Bend, Oregon
    Very Nice work and a unique approach! Are the exhausts going to exit thru the humps? Now that's novel! (You may be breathing fumes though).
    I'd love to put an H6 in an R and race it, if only someone could come up with a dry sump solution for the 30 or 36.
    818R ICSCC SPM
  31. #151
    Syracuse, NY
    Purely racing and no sound limits at the tracks I go to.
    Not sure what your looking for? Can you explain it differently, maybe I'm being dense.
    They will exit through the Mechie hump vents, so you won't see the pipes. Talked about this in a previous posts and the consensus is that the R does not suffer from the back flow issue that the S does with its high windshield. I'll know for sure next spring!
    I'm hoping I don't need a DS. The EZ36 holds 8.2 quarts of oil in stock trim. With my external cooler and Accusump I'm at 10 quarts! I have equipped pressure sensors before and after the Accusump so I can monitor the pressures and know if the oil pickup is sucking air BEFORE the engine loses oil pressure while the Accusump if supplementing the prerssure . I won't know for sure until I can get some data logs and check the oil pressure differentials. I do have a DS system planned out if I see any pressure loss before the Accusump.
  32. #152
    San Diego Ca 92106
    Sorry John, I'm not the best in composing questions. But a picture is worth a thousand words right? The attached picture shows the the perspective I'm asking for. A photo from the firewall to the rear hubs.
  33. #153
    Syracuse, NY
    I'll try to get one tomorrow.
  34. #154
    Leesburg, VA
    Are you concerned about the air pressure being greater outside the vents such that it may force the exhaust gases into the engine bay? Or are you going to make some sort of exhaust shroud? Also, wouldn't the exhaust pretty much cook those vents and the fiberglass they're attached to?
  35. #155
    Syracuse, NY
    I plan to seal off the exhaust to the bottom of the vents with an aluminum box. The air rushing over the vents should draw the exhaust out as well. Not sure about the heat cooking the aluminum, guess I'll find out
  36. #156
    Syracuse, NY
    @flynntuna - I sent the headers off to be ceramic coated, I'll get you the picture you asked for when they return.
  37. #157
    San Diego Ca 92106
    No hurry John, quick question though. What size turnbuckle did you use for your altenator?
  38. #158
    Syracuse, NY
    I used an aluminum swedged 3/8-24 panhard/radius rod, 4 In.
    Here is a list of what I used.
  39. #159
    San Diego Ca 92106
    Thanks John
  40. #160
    Syracuse, NY
    While my headers are out being ceramic coated I thought I would start working on some of my aero ideas.
    One of the problems with the rear wing is that it generally sits behind the rear roll bar and the disturbed air reduces the wing's effectiveness. You can raise the wing above the bar, but that makes the wing sit quite high. I remember a post a while back that suggested creating an ideal airfoil (tear drop shape) around the roll bar to smooth the air flow. This is a strut cover for an ultralite's landing gear. It's the perfect size for our roll bar tubing!
    If you slit the trailing edge, it will slip over the bar easily. I plan the secure the airfoil to the roll bar using flush mount rivits. Then wrap the airfoil with the same carbon fiber vinyl car wrap I used on the interior panels. That will seal up the slit I made on the trailing edge and presto, a functional fairing that should smooth out the air going back to the wing!
    What do you think?
