Results 1 to 11 of 11
Thread: Lack of spare tire options?
Hybrid View
    Nov 2015
    Elverta, CA
    My car will be driven quite a bit on long hauls around the west once I get her done. I've used runflats before and don't want them on this hot rod. I will have road service of course but I want an extra bit of insurance to cover that flat in the middle of nowhere, Nevada. Are modern "flat fix in a can" products suitable? If I carry some tire plugs, glue, and the tools, will CO2 cartriges work to inflate a tire as large as 255/45-18? Should I carry a 12v pump and if so, recommendations? Thanks gang!
    wallace18's Avatar
    Trenton, Florida
    I carry tire plugs and a 12 compressor.
    Seasoned Citizen NAZ's Avatar
    As an avid off roader and former desert racer I have lots of experience with breakdowns in remote places. I always carry a couple cans of flat fix, and a tire plug kit and these have got me out of some bad spots. A small 12VDC air pump is handy as the flat fix may not inflate your tire enough. Buy a small cheap Harbor Freight pump and consider it a throw away after a couple of uses. Yes there are better ones out there but they are substantially bigger and heavier and you don't have a lot of space in that little car. Very seldom do I purchase cheap tools but this is one time that the made in China tool is my first choice. And always bring your AAA card -- don't leave home without it.
    We've got 12-Volt Air Compressors in all of the cars and plug kits too.
    Home Depot had the compressors for a nice price so everybody in the house got one for Christmas.
    Add a set of inexpensive pliers (Cutting, Needle Nose, Standard & Channel Locks) and you are typically in good shape to fix most punctures.
    While my driving minions weren't too thrilled about this stocking stuffer, the GoDad thought it was a good gift to keep them Going!
    I carry a compact spare. It was from an Edge IIRC and cost $35-50 at a salvage yard
    At 4.5" wide it will fit in my trunk but I moved my fuel tank so YRMV
    Its a T165 80 D 17 so it also clears my 13" rotors
    Spare tire, yet one more reason to ditch the FF fuel tank.
    DB
    May 2016
    North of sacramento Ca.
    My mini has no spare so have always had 12v pump and plug kit, most of the time put in air and go get it fixed.
    I've done several blistering hot summer cross country tours. I carry plugs and the special tool, and bought a small 12v compressor from Honda (for use on ATVs) but can produce 100 psi......more than needed. I feel confident I can made roadside repairs for small punctures. Anything more severe will mean a call to CAA.
    Never had a car without a spare.
    Never used fix a flat.
    Was planning to have a couple cans in my trunk kit. Is this inadequate for an emergency repair and to get me 10 miles or so?
    Senior Member TDSapp's Avatar
    Frisco, TX
    Maybe you need to talk to Erik Hansen about adding something like this to your car.
    Over one third of new cars now no longer include a spare tire. Some have run flats, but much more common is an inflator and sealant. These are typically integrated into a single unit and are actually pretty nice if you can find one. I remember some years ago seeing a pre-production Chevy Volt at a business conference. A GM executive was giving a speech and brought the car for us to see. The company I worked for had a lot of content in that car, so we looked it over very closely. I immediately noticed it didn't have a spare and only a pump and sealant. Wasn't as common then, but much more now. I carry a pump and sealant in my Roadster, but would only use it as a last option. Spare tire is out of the question.
    One thing to keep in mind if you figure out how to carry a spare tire is how you're going to jack it up with a flat tire. The frames on these cars are so low that with a flat it's not going to be easy to raise it to make the change. Probably some type of low profile bottle jack. More weight and space...
    Nov 2015
    Elverta, CA
    Thanks for all the great feedback. I gave thought to the bike rack but figured it would get in the way of the 10,000lb winch that gies back there!
    Seriously, the idea of a combined pump, plug kit, and selection of plugs should give one plenty of comfort on a long drive. I thought about various jacking options and will probably carry the tiniest bottle jack I can find. Thank you all for the help. Tom
