Thanks Thanks:  114
Likes Likes:  679
Results 1 to 40 of 1015
Thread: Star Mobile 1 Build
Threaded View
  1. #10
    Senior Member JOP33's Avatar
    Haslet, Texas
    Only a few things done today and really more just for fit up and prepping for paint. As I have mentioned before, I will be handing Star Mobile One off to the painter to complete the majority of the rest of the work...all body panel fit-up, prepping & painting. So part of what I wanted to start doing is just dry fit some components and locate and install (temporarily) the hardware, in hopes of making it just a bit easier on the final install and to familiarize the painter with what hardware goes where (although Kory is the painter that Bill (WRP) used on his Green 33, so I am pretty confident there shouldn't be too many hiccups. So here are just a few pics of the work from today, again nothing has been installed permanently today or in the correct order for that matter ...
    Just a couple additional comments, I did opt for Tim Whittaker's (KVC) bushing package for the Trunk, Hood and the Door Hinges. I believe I have them installed correctly now (the washers that is), but I have an email in to Tim to confirm.
    Trunk Hinge...
    Door Hinge Bushings (Kootenai Valley Customs)...
    The top (2) bolts on the Hinge Brackets are (were) extremely difficult for me to get in place due to the slanted geometry of the Brackets, so I ended up shaving the heads down a bit, so they would clear a little bit better. Only the top (2) required this and even then it was still bit of a challenge (and this was a dry fit, can't imagine trying to install with doors in place, etc).
    Hinge Bolt Lengths...
    Difference between shaved and non-shaved heads...
    Top Hinge Bolts that were difficult to get in...
    Driver's Side Hinge & Door Bracket dry fit-up...
    Passenger's Side Hinge & Door Bracket dry fit-up...
  2. Likes coolair247 liked this post
