0
0
Originally Posted by
Jeff Kleiner
The hard steering without it running is because you're having to manually force through the rack, transfer lines and pump. Do it enough and it'll belch fluid out of the vent hole in the pump cap.
Jeff,
I was doing it while cycling thru Camber, Caster and toe. Good to know nothing is wrong.
Thanks, Jay
