Results 1 to 3 of 3
Thread: Coolant Leaks
    Des Moines, IA
    Coolant Leaks
    Anyone else had trouble stopping coolant leaks on their connections to the side pipes and at the pump? Tried about everything, and still get a slow drip sometimes
    Constant tension spring hose clamps (like this style https://www.amazon.com/Constant-Tens.../dp/B0040CRUWK) work much better on coolant lines than worm drive clamps. If using worm drive clamps, you'll need to snug them up a bit after heat-cycling the engine a few times, and then possibly additional times in the future to prevent leaks.
    The other thing is the rubber couplers and adapters FFR provides. I didn't like them. Instead I just bought a couple extra upper radiator hoses and cut them up so I had some straight sections to use as couplers. I used these to connect the flexible heater pipe to the solid heater pipe, and to the water pump. I have not had a single coolant leak.
    Des Moines, IA
    Good advice. Thanks
