Thread: Race Setup changes on my Electric
    San Jose, Ca.
    Hello All,
    I finished all my changes to my Electric MK2this weekend I preparation for an event this coming weekend at Laguna Seca. Here is the list:
    17"-10" RPF1 wheels with A7's. Changed from 17" Pin Drive. This saved me 17lbs. per wheel and tire.
    Front air dam, with 3.5" splitter
    full under tray, with rear defuser.
    Tonneau cover
    adjustable rear spoiler
    Also removed my 2 speed Powerglide Trans. If setup works on track will add electric reverse.
    changed to a 2.73 final drive from a 3.08.
    The changes got the weight down to 2,100 lbs, down from 2,250 .
    Here are some pictures of the changes.IMG_0506.JPGIMG_0508.JPGIMG_0515.JPGIMG_0516.JPGIMG_0519.JPG
    Wow.
    I wanna see that thing go! Got any video?
    Jun 2015
    Fairfax Station VA
    I'll be interested to hear the results.
    MK IV Roadster #8631
    San Jose, Ca.
    Iwill link a onboard video from last years event when I get home.
    You can do a Google search under Electric Cobra Laguna seca
    Wow.
    Wow! Watched the Laguna Seca video. Very cool. This is the first I have heard/seen of an electric Cobra. Do you have the build documented online anywhere? Would love to learn more about how you did this.
    Well done!
    San Jose, Ca.
    Well done!
    Here is the build thread on FFCars,
    http://www.ffcars.com/forums/17-fact...r-begin-5.html
    San Jose, Ca.
    Wow.
    Here are a few video's......
    https://www.youtube.com/channel/UCUJ..._as=subscriber
    San Jose, Ca.
    Ok, weekend went great !
    Car changes all worked as designed. The only change made was to increase the rear spoiler angle its highest angle (72 deg.) Because the car wanted the over steer coming over the start finish crest if I lifted off the accelerator.
    I could only do 4 laps at a reduced power level (185hp, 600 torque) before the air cooled motor got to hot. In the one lap time trail I turned it up to 300hp and 1000plus foot pounds of torque and the motor was over temp in the one lap. I didn't use dry ice in my cool box that feeds the motor, because last year my carbon brushes all cracked and fell apart due to the cold shock. I think this was my fault, because I forgot to turn on the motor fan for about half a session and when I came in to re-charge, I added more dry ice . I think this shocked the over heated brushes. Next time, I will use dry ice only when the motor is cooled down from the beginning of a session.
    The weakest link of my car is still me ! I need to go to the track more than once a year to keep my reflexes in tune. Their is an easy 4-5 seconds in the car to be had.
    Oh yaa, the lap time from the TT was a 1:51. I missed the conversion record by two seconds Oh well , get-em next year !
    https://www.youtube.com/watch?v=HuYvioNyWIw
    https://www.youtube.com/watch?v=gfKsM7XnwM8
    Senior Member R Thomas's Avatar
    Jan 2015
    Wow, this is awesome and interesting development of kit. Congrats and best of luck on getting that record.
    Daily Driver 2011 Ford Mustang Convertible
    Donor 1997 Mustang Coupe
    Someday a Type65 Street Coupe
