Results 1 to 21 of 21
Thread: Anyone using the 0-60 function of the GPS speedo?
    Curious what times people are getting using that function?
    I haven't tried it yet but intend to soon. My wife rode with me this morning. Thought it might be prudent to wait until my next solo ride....although she could take video...
    War Eagle,
    My pal and build buddy (Forum Member / Hottrodder427 / Donnie) has the GPS Speedo and is getting 3.5-3.9 second 0-60's.
    390 FE bored to 396 cubes / Edelbrock Heads / Roller Cam / TKO 600 / 3.55 Gears / Independent Rear Suspension.
    The times vary a bit, but he's not speed shifting and wheel spin is an issue.
    Oct 2014
    Hi GoDadGo,
    Can you define "speed shifting"?
    Senior Member jlfernan's Avatar
    Port Orange, Fl
    Quote Originally Posted by Duke66 View Post
    Hi GoDadGo,
    Speed Shifting = Shifting just as fast as you would power shifting, using the clutch, but only lifting about half way off the gas.
    Hi GoDadGo,
    Speed Shifting
    Shifting gears at full throttle (Never Lifting or Lifting Minimally) accompanied by applying a fare amount of pre-load pressure on the shifter handle so each gear is changed as soon as you do a super quick depression of the clutch. Understand that shifting in this manner is very rough on the entire drive line and it is advisable to have a good rev limiter to keep you from blowing up your engine in the event that you miss a gear.
    Granny Shifting
    Take your time between shifts while letting the RPM's drop to proper RPM levels so that minimal stress is exerted on the driveline.
    Video Example Of Speed Shifting
    https://youtu.be/yjmziYBfN1s
    https://youtu.be/aqeLq9pyVyw
    Super Moderator
    Ray's Avatar
    La Mesa, California
    I don't have that speedometer, but do have this: http://www.autometer.com/2-accelerat...ltra-lite.html
    I'm also getting sub 4-sec 0-60 times.
    Ray
    I tried it for the first time with the Speedhut GPS speedo yesterday. Pretty cool. Once you have it in that mode and are stopped, you push the button to stage. It starts the timer automatically when you start moving and stops the timer at 60 mph. (Similar function for a 1/4-mile time BTW.) Interestingly, it not only gives the 0-60 time but also the number of feet traveled. My one time using it was at a corner turning onto a highway into traffic. I staged before I turned and didn't push hard. It was something around 7 seconds. Not very meaningful in that situation, but nice to see it work. I'll be trying it more. Wished I had used it when I was giving charity rides at London last Saturday. But too much going on right then and didn't need the distraction.
    Quote Originally Posted by Ray View Post
    Ray
    Ray,
    Man I wish I would have seen that gauge before I wired my dash!
    That is really one neat piece!
    Well on my evening ride I gave it a trial run. Frankly I don't think I have enough experience in the car to be at a comfort level for a 100% run in the car nor did I have the appropriate road to try it on. But I did find myself first in line at a long stop light so I fiddled with the button and staged it. I would say I did about a 75% acceleration and clocked at 4.72 and 228 ft. Sub 4 seconds is certainly attainable. I knew the car was fast but pretty cool to see it quantified on the gauge.
    PS. My wife was riding copilot. I did not tell her what I was doing and just took off. She was not pleased! LOL
    Oh and no fish stories here please. Pictures or it didn't happen. Hahaha
  10. Likes JWolfe liked this post
  11. #10
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Ray,
    I had before I retired. Was using it to gather data for collision reconstruction work. You can get positive/negative and lateral G's, 0-60, 60-0, qtr mile time and est hp based on weight and qtr mile times. It is really fun to play with....... I used crop dusting air strips on friends ranches in the Fresno/Madera CA area for my "fun"
    You can get a pod from Autometer (http://www.autometer.com/2-mounting-cup-black.html) and attach it under the dash.
    Ray
  12. #11
    Sacramento CA
    Does the gps speedo also get a signal from the trans for speed or just gps for everything?
  13. #12
    Quote Originally Posted by Just puttering View Post
    Gps replaces the need for signal from transmission. All done with Gps
  14. #13
    Senior Member Yama-Bro's Avatar
    Jul 2012
    Kearney Nebraska
    Are these the speedos that come with the kit? I upgraded to the vintage gages. This looks like a fun thing to play with, so I'm hoping that's what I'll be getting.
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
    Serial #9158
  15. #14
    Quote Originally Posted by Yama-Bro View Post
    If this is what you ordered, then yes. "#16007 - FACTORY FIVE VINTAGE GAUGE SET W/GPS SPEEDOMETER"
  16. #15
    Calgary, Canada
    Holy ** these are quick! I still haven't driven mine. 4.72 is still quick Scott!!
  17. #16
    Senior Member JIMOCO's Avatar
    Aug 2013
    Camp Hill, PA
    For those of you that do not have the FFR GPS speedo, I downloaded a free app called Ulysse Speedometer to my smart phone. It will give you 0-60, 0-100 and 1/4mile times. Also current speed, average speed, weather temp, elevation, trip times and miles, miles today, yesterday, week, month, compass and more.
    Mk4 Roadster, Picked up complete kit 8/22/14. Most FFR options except Wilwood brakes and IRS. First start 11/11/14. Go-kart 3/8/15. 347 Stroker, TKO 500, 3-link/3.27 rear. PA street legal 7/29/15.
  18. #17
    Quote Originally Posted by chopthebass View Post
    That is what I was thinking when I saw the time! haha
    Like I said I was only going about 75% and didn't mention it but I was going up a big hill as well. Should be fun to see what kind of time I can get under the right conditions.
  19. #18
    Jul 2012
    Kearney Nebraska
    I checked my order form. Mine are 16004, which appears to be the same thing, just coded as the upgrade to the kit. I watched the video and Dan G stated the 0-60 times as a feature, along with a bunch of other stuff. Cool. It's like icing on the cake. =)
    Serial #9158
  20. #19
    Yea, that looks like the part number on the kit order form. Plus it's described as the GPS version. The number I referenced was from the parts catalog. If in doubt, you could call them. I'm sure the could quickly confirm if any doubt.
  21. #20
    Calgary, Canada
    I must have got mine just before they amended to gps! I'm not taking the dash out now!
    I would like a 0-60 phone app too, but none of the ones recommended seem to be available in Canada. We have a tough time getting anything here!
  22. #21
    Dec 2014
    Gurnee, IL
    Speedhut can convert your speedo to the gps version, I remember it as being very reasonable also had them remove the F5 name from the faceplate.
