Results 1 to 9 of 9
Thread: Coyote / Moroso coolant tank mounting
    Feb 2017
    I plan on using the Moroso coolant tank with my Coyote.
    I have seen a couple of pictures showing how others have bent some tabs to mount it to the upper radiator support tube.
    I can't find any that show how it gets supported from the bottom.
    Anyone got a pic or simple description?
    Greg
    Senior Member Jdav's Avatar
    ATL GA
    I followed EdwardB's lead and made a little tab that mounts to the radiator shroud and provides support from the bottom.
    Mine are not nearly as pretty as his: http://thefactoryfiveforum.com/showt...oso#post220495
    MK4 #9028 - Coyote - TKO600
    Member Larry Johnson's Avatar
    Apr 2015
    Colleyville, Texas
    Watch the distance between the tank and the PS to allow the hood hinge to fit. I just had to move my Moroso tank over toward the cold air unit to give me space for the hinge. It is a tight fit, but it does work.
    Larry Johnson
    Colleyville, Texas (DFW area)
    2016 Mark IV complete kit
    Delivered March 3, 2016
    New 2016 Roush Coyote engine w/453 hp
    2016 IRS, Tremec T600 mid shifter
    Raleigh NC, OIB NC
    My middle lower support piece is the same aluminum bar stock as the two short end pieces. Its just bent to follow the contoure of the tank. Bolts to the lower tank tab & the radiator support bar.
    Kevin
    MKIV #8234
    Feb 2017
    Quote Originally Posted by Jdav View Post
    Thanks for the link. Looked through his for pics but didn't see that one.
    Brentwood NH
    bottom support??
    Brentwood NH
    deleted. double post
    Raleigh NC, OIB NC
    Quote Originally Posted by MisterAdam View Post
    bottom support??
    Tank has 3 mounting tabs. Two at the top corners & one at the bottom center.
    Kevin
    MKIV #8234
    Brentwood NH
    my point was i have not used the bottom support. Third summer and no issues using just the top 2.
