While trying to figure out the routing of the engine bay wiring, it looks like the engine is forward a bunch.
I measured from the firewall to the back of the block, where the bell housing bolts up. The distance is somewhere around 7 5/8 to 7 3/4". I realize the angle of the engine will affect this distance, but it looks like the engine is way forward. The motor mounts are seated good and bolted in.
To get some more accurate numbers I measured from the front of the motor mount frame to the rear of the lower control arm mounting flange. Pass side 14 1/8" Driver side 14 7/8".
Can someone confirm my engine is sitting right.
Another reason I ask, is my engine is against the drivers side foot box.
