Results 1 to 32 of 32
Thread: Finished with my 33
    Foristell Missouri
    Finished with my 33
    It's been a great experience and I've learned a lot along the way. All I need to do is a front end alignment and get it inspected and titled. #622 is pretty much done. 351c, TKO600, 9" rear end. I thought I would be done late last year but some health issues kept me from doing much until a few months ago.
    Thank you Factory five for your help.
    -Larry
    Oct 2014
    Vermilion, OH
    Larry,
    The car looks great!!!
    CVOBill
    That's A Killer Kolor!
    That's not exactly how we spell down here in the South, but the "K" looked "Kool!"
    Larry,
    Fantastic job. Another one of those 40 posts to completed car guys eh? I had 1000 posts before my first FFR order!
    We all take our own path; that's part of the fun. Congratulations, and well done!
    PS Get some great glamour shots; we STILL haven't had a Hotrod POM!
    http://thefactoryfiveforum.com/misc.php?do=form&fid=13
    Banned
    Loveland, CO
    Nice work, but I'd add safety pins to the doors. Not including them in the kit is a crime.
    Foristell Missouri
    I'm working on coming up with a safety pin system that will fit in the doors with the power windows. I bought a set from Carolina Customs but they are too long. That and finishing a front nerf style front bumper are a few misc. items to do over winter.
    Nice job on the console, great Kolor too
    Dale
    San Jose, Ca.
    Beautiful ! Very nice. I like the chrome side hood pieces.
    Senior Member kraftee's Avatar
    May 2013
    Gainesville, Florida
    Suicide Pins
    By far the best looking full-fender 33 I have seen! Great job! I too purchased the Carolina Customs Suicide Pin Kit. Now, although my car does not have power windows or outside door handles like yours does, I wonder if you could sneak the pins into the same unusual location that I used? They work great. ERIC
    "If everything seems to be coming your way, you're probably in the wrong lane."
    Foristell Missouri
    I will have to check to see how much room I have there. That is a great location. Your safety pins look a bit shorter than the the ones I bought, are they manual? Mine has the electronic solenoids that can be wired to the ignition switch. Thanks for the suggestion.
    Stunning looking car! you did a fantastic job!
    Beauty!
    Love those full fenders. Great job
    Very nice looking car. Congratulations
    Gatineau, Quebec, canada
    Beautiful!!!! Love the fenders as well. And on that subject would it be possible to see how you mounted the front and back fenders?? I just posted this and would really be interested in how you did them. The more I can do in advance, the better especially since I am just starting my build! Anything you would share is deeply appreciated, TY!
    Quote Originally Posted by kraftee View Post
    Like this too! Will be looking at doing this as well, will be more comfortable with a system like this on the doors. The car inspectors will most likely require this as well. TY!
    Ol Skool
    upstate NY
    Congratulations! Great Job. Suicide pins should be in the kit for sure. Even if your door latches are done correctly, a passenger will inevitably not get the door fully latched eventually or if you drive hard the body will flex and release the door. Been there, experienced it, got lucky. The stops on the hinges can generally be a little taller also as the door can "climb" over it with enough encouragement. I used small diameter lock washers under the Hex head to raise them up a little.
    Enjoy your ride!!
    Great job ! I like details like the ventilation louvers, very beautiful
    Jan 2016
    Beautiful job Larry, motivates me to work on my hard top
    Prairieville, Louisiana
    Seeet! Nice car!
    '33 Hot Rod
    MK4 Roadster
    Foristell Missouri
    Mounting the front and back fenders was pretty straight forward. At the time I bought the kit I did not get instructions with the full fender option. That may have changed by now. We did a bit of tweaking on the back fenders. We shortened them a bit and corrected a few imperfections that is typical with most fiberglass that comes out of a mold. We did add some reinforcement webbing on the front fenders to make it a bit stiffer. The biggest challenge was the running boards. They come with no support brackets and will not support someone standing on them. We felt that would be problematic unless we reinforced that with metal brackets underneath. I think most of the posts I have seen with the running boards did some sort of reinforcement. We also made the side panels into two piece units so we can access the engine to change plugs or oil easier. The Cleveland engine is a little wider than a 302, so getting to everything from the top is a bit tight.
    Foristell Missouri
    I want to thank everyone for your kind words and suggestions. Hopefully, I'll be getting a drive time in before winter.
    Senior Member bil1024's Avatar
    NY
    Looks awesome
    Great build looks great I cant get mine fast enough but I have to wait till next year. I noticed you put in a 351 did you have any problems with it as far as installation because I have my 351 just collecting things as I go so when my kit gets here I can go to work and not have to wait on anything. Sharp ride. What transmission did you use on the 351?
    Foristell Missouri
    I had a few issues using the 351 Cleveland motor. It would have been quite a bit easier going with a 351 Windsor motor but I already had this really nice Cleveland sitting in the garage that I figured I would try to use. The motor mounts and bell housing is the same as the 302 /351 Windsor but getting off the shelf headers to fit without going with custom made units was my most difficult issue. I used a Tremec TKO600 5 speed transmission. Great transmission.
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Beautiful!
    Kyle
    Senior Member Taz Rules's Avatar
    Dec 2012
    BC, Canada
    Love it!
    You should submit it for the calendar! (See thread http://thefactoryfiveforum.com/showt...l-for-pictures)
    Oct 2017
    I can only hope when I get to start on a 33 it looks half as good as what you have done...great build
    Seasoned Citizen NAZ's Avatar
    Beautiful car -- great job. What color is that blue? I love it on that car!
    This is awesome!
    I love the color! (Although, I am partial to blue)
    Just saw that you are in Foristell. Would love to come see it in person.
    Foristell Missouri
    It's called Laguna Blue. PPG calls it "Blue my mind"
  31. Thanks clays123 thanked for this post
  32. #31
    Foristell Missouri
    Hi Bob,
    Let me know a week or so in advance, Weekends are usually best.
    -Larry
  33. #32
    mcwho's Avatar
    DeBary - Florida
    That's absolutely Beautifull !!!
    Baghdad Bob
