0
0
Originally Posted by
grluisi150
I'm looking at changing out the FFR SS glass pack side pipes with 24" Slimline pipes. I noticed that everyone is using the 30" pipes. Did anyone use the 24" pipes? is their any drawback in using the 24" vs 30" pipes (besides the obvious 10").
Gary
The glasspacks welded in the FFR pipes are actually 24" long with 2" inlets and a 4" OD but the weld lines are 20" apart because of the taper of the muffler ends. The 3.5" Pipes hide about 2" on on each end of the original muffler. The Slimlines have 3.5" inlets so there is actually a 10" difference in the weld lines when using the 30" Slimlines hence the 10" comment. The pipes will be about 2" longer after welding in the Slimline but there is ample room between the turn out end and the rear fender flare for the extra length.
