Results 1 to 8 of 8
Thread: Brake line routing through firewall
    Jun 2017
    I am looking for pics on clean way to route brake/clutch lines through firewall. I purchased a triple brake/clutch reservoir that I’m mountain just outside firewall.
    Three hoses and three 3/16 Steel lines.
    Thanks!!!
    Here is what I did:
    I have the triple reservoir mounted on the frame rail. A little hard to see in this pic.
    Fairfax Station VA
    I routed my reservoir lines the same as Scott, but took my front brake line out with the lower 3/4" frame member.
    IMG_2164 by jhsitton, on Flickr
    MK IV Roadster #8631
    Through the clutch cable opening since I am using a hydraulic clutch
    Tybee Island, GA
    It's a mess right now, but in this photo you can see my reservoirs mounted to the firewall and will pass through the footbox to the master cylinder. The hoses will be hidden once the aluminum is in place.
    20171017_181243 by D. R., on Flickr
    Videos are at: YouTube Videos
    Senior Member karlos's Avatar
    Littleton, CO
    One more option: bulkhead fittings.
    Santa Clarita, CA.
    I wanted to eliminate using bulkhead fittings. I drilled the holes just large enough to pass the fitting through and used grommets. Worked out great. The actual brakes lines I ran along side the 3/4" frame tubing and sealed it later.
    Jun 2017
    Awesome!
    Thanks for the suggestions guys!!!
