Home made front battery box for a group 51 size battery. Has no trouble starting my 302. Just a bit of angle iron, neighbors mig welder, hammer, saw , and some heavy duty self tapping bolts I found at tractor supply. Used the battery hold down that came with the kit (not pictured).
In the trunk using the dropped trunk space to slide the battery on its side into the space available over the pumpkin.
