0
0
If the OP's intent is handling above all I still think this setup in a cobra would be sweet.AAfirMp.jpgAAfiHiU.jpg You could really lower weight and help cg at the same time. Do the engine in black/satin aluminum theme with all black an fittings and lines, etc. The exterior in metallic black w/ aluminum silver stripes... I'm a V8 guy but still think this would hit the mark for better handling, something different, and still FORD. No need for a double-hump oil pan here. That's a lot less weight, a lot further back towards center.
