16
4
P100DHG
Does the brake fluid reservoir need to be higher than the master cylinders?
Interesting question especially based on the directions in the manual that say "Keep the reservoir high enough so that the lid is higher than master cylinder." I trust this would work, but I prefer to have the outlets of the reservoir(s) the same height or slightly above the inlets to the master cylinders. Plenty of room under the Coupe cowl to position the reservoir(s) that way.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
