0
0
Help Already
I'm not sure what section to post this under, so hopefully someone sees it here. The first mention I see in the manual of the "OEM pedal box front plate" is in the first steps of assembly. I apparently did not save that piece from my donor. Any advise? Anyone do a non donor build and have an answer? Short of finding one in a scrap yard.
Did you save the pedal box? I think the front plate refers to the front of the pedal box or the plate welded to the chassis. Not s separate piece.
Originally Posted by
michael everson
Mike,
I saved the pedal assembly, but apparently not the entire box.
David,
Reach out to David Hodgkins and ask him to upgrade your account so that you can post pictures and then post a few pics of your issue.
It will really help the folks on the forum see what you are talking about so that we can be of assistance to you.
Also, any advice that you get from Mike Everson will be based on fact and experience.
He is a Professional Master Builder and knows these cars like the back of his hand.
As for me, I'm also am a 1st time builder so good luck because we all get stuck from time to time!
I don't believe there is anything related to the pedal box besides the whole assembly the pedals are a part of. Are you sure that's not referencing the aluminum firewall piece provided by FFR?
Edit: I believe you're referring to the piece that the FFR has you bolt on for the brake booster mount. It comes with the kit and must be painted/coated as desired. See image attached.
I had the same panic and confusion...
the plate is not OEM part... it is a plate for the OEM pedal box. The manual shows the cad image of the plate (I'd try and snap an image, but I have my 9-day old little girl in hand).
LSfourwheeler nailed it; the part circled is what your looking for:
MonzaMan
Thank you guys, this was my first of surely many knucklehead moves. I found the piece you guys were talking about and all is good again in my universe.
HA! you should search through MY posts sometime...
- You may not post replies
- You may not edit your posts
Forum Rules
