Results 1 to 11 of 11
Thread: under car exhaust has anyone done this ?
    Sep 2019
    Has anyone done under car exhaust on there F I A
    SW Fl
    You might want to contact 65 Cobra Dude, he did an excellent under car exhaust on a roadster recently.
    Senior Member EZ$'s Avatar
    Feb 2014
    San Ramon, CA
    2Fast4U did it on his 289FIA. Check out his build thread.
    Rick
    Sep 2015
    Beachside
    Eddie (vspeeds) did one too. Came out real nice.
    FFR #8833 289 FIA 3-link
    Member Zots's Avatar
    Montgomery TX
    You can check out my 289 build thread.
    Quote Originally Posted by Zots View Post
    Zots,
    Were those Spintech Low Profile Mufflers that you used?
    https://spintechmufflers.com/3000xlf...ofile-muffler/
    Montgomery TX
    Zots,
    SpinTech Cruiser 7000 Oval outlet Muffler: The CRUISER muffler measures 2 1/4" thick, that is the flattest Performance muffler available! I used the 2.5" oval side exit. It tucks up nicely under the MK4 raised seat area.
    https://spintechmufflers.com/street-...r-low-profile/
    I did it on my build. I’ll post some pics
    I had a custom exhaust shop make custom headers from 1-5/8 mild steel and use a V-band clamp to attach the pipes to. They were later ceramic coated black
    The pipes run under the car under the seats. The mufflers are under the seats
    I added 90 degree turns that exit in front of the rear tires. Tubing is 2-1/2” mild steel, now painted black to the mufflers, and aluminum colore from the muffler outlet to the exhaust outlet. I had to make custom hangers
    Sep 2019
    Thank you for all the info Sorry its been awhile . Still deciding if I want to build again its been 20 years since the my first one . Has anyone found or made the flat exhaust pipe like you see on nascar just a though
    Thanks again Pete
    CobraboyDR's Avatar
    Jun 2017
    I am also interested in undercar exhaust, but with a rear exit. I'm pondering a AC 289 Sports Mk.III replica, pure street car, small block, undercar exhaust, no scoop or roll bar and wire wheels.
    The challenge I see is exhaust system ground clearance under the main frame cross members of a FFR. A system under these members gets really close to the ground. The rest, around the rear suspension, I believe can be worked out without a lot of stress.
    I'm also looking at C3 Corvettes (not either/or, but both; I like C3's.) The C3 makes a nice platform for inexpensive performance upgrades in a cruiser. In a C3 Corvette, the main cross members have two 3" tubes firmly welded in them, and the exhaust pipes go through these holes. I have not ever heard of a frame failure from these welded tubes. They also have engine-hugger headers.
    I can understand the angst some might experience in drilling big holes in cross members, but would not this be a more elegant solution? Then run pipes through these holes? And would proper cutting, insertion of a 3" pipe through the member, and good welding not weaken the frame? I mean, the car is light so the stresses are minimal.
    And with the absence of side pipes and the gap in front of the footboxes to route them, would this also allow footbox modifications that could allow size 12+'s on a larger human with comfort? Imagine another 1-2" of room to the pedals!
    Am I missing something?
    What say you?
    (Edit) This is an AC 289 Sports Mk.III:
    (Yeah, I know, that's a "narrow hip" car. True enough. I guess you can't have everything, and a narrow hip conversion is waaaay too much work, and only a mega classic Cobra geek like yours truly would know the difference...)
