Has anyone done under car exhaust on there F I A
You might want to contact 65 Cobra Dude, he did an excellent under car exhaust on a roadster recently.
2Fast4U did it on his 289FIA. Check out his build thread.
Rick
Eddie (vspeeds) did one too. Came out real nice.
FFR #8833 289 FIA 3-link
You can check out my 289 build thread.
289 Build Thread: https://thefactoryfiveforum.com/show...9-Build-Thread
Zots,
Were those Spintech Low Profile Mufflers that you used?
https://spintechmufflers.com/3000xlf...ofile-muffler/
SpinTech Cruiser 7000 Oval outlet Muffler: The CRUISER muffler measures 2 1/4" thick, that is the flattest Performance muffler available! I used the 2.5" oval side exit. It tucks up nicely under the MK4 raised seat area.
https://spintechmufflers.com/street-...r-low-profile/
Thank you for all the info Sorry its been awhile . Still deciding if I want to build again its been 20 years since the my first one . Has anyone found or made the flat exhaust pipe like you see on nascar just a though
Thanks again Pete
I am also interested in undercar exhaust, but with a rear exit. I'm pondering a AC 289 Sports Mk.III replica, pure street car, small block, undercar exhaust, no scoop or roll bar and wire wheels.
The challenge I see is exhaust system ground clearance under the main frame cross members of a FFR. A system under these members gets really close to the ground. The rest, around the rear suspension, I believe can be worked out without a lot of stress.
I'm also looking at C3 Corvettes (not either/or, but both; I like C3's.) The C3 makes a nice platform for inexpensive performance upgrades in a cruiser. In a C3 Corvette, the main cross members have two 3" tubes firmly welded in them, and the exhaust pipes go through these holes. I have not ever heard of a frame failure from these welded tubes. They also have engine-hugger headers.
I can understand the angst some might experience in drilling big holes in cross members, but would not this be a more elegant solution? Then run pipes through these holes? And would proper cutting, insertion of a 3" pipe through the member, and good welding not weaken the frame? I mean, the car is light so the stresses are minimal.
And with the absence of side pipes and the gap in front of the footboxes to route them, would this also allow footbox modifications that could allow size 12+'s on a larger human with comfort? Imagine another 1-2" of room to the pedals!
Am I missing something?
What say you?
(Edit) This is an AC 289 Sports Mk.III:
(Yeah, I know, that's a "narrow hip" car. True enough. I guess you can't have everything, and a narrow hip conversion is waaaay too much work, and only a mega classic Cobra geek like yours truly would know the difference...)
