I am using the upper shock mounts for the R ride height, but I did read some noted this may not be the best place to achieve a ride height of 3.5-4.0". So I will have to see how it works once I get it on some wheels and then if needed I can use the lower S holes if I need more adjustability. For now the rear suspension is complete and torqued down. Aligning this is going to be quite a project with how many different links can be adjusted!
Next up is to finish mounting my seat and possibly compressing the steering column a couple inches. The Holley hydramat I ordered is on back order until the end of Feb so that is a bummer. My fuel tank has an extra 1.3125" hole in it and FFR mentioned this is for a roll over / fuel vent. However, there is no mention of this in the manual nor 818R supplemental instructions, but FFR said they are going to send me the valve. Guess I will see what it looks like when I get it. I had a hard time finding something that large of a diameter on my own.
