38
172
I cut off a couple inches of the fuel hanger to see how I can clear both floats and fit the hydramat in the FFR gen 2 tank nicely. In the first picture you can see where the floats rest initially and how close they are. The FFR tank is shorter than an OEM WRX tank so the floats are both raised a bit when they are installed. I am not sure how this will affect the fuel gauge readings. I am trying to figure out how to make it all fit. I started to bend the fuel pump float arm to the left in the picture to try and give some space. I suppose I can do the same to the sub fuel level float on the right since this one is right under the fuel pump hanger. Any recommendations would be appreciated!
I apologize the first two pictures are upside down. I could only get a picture through the small vent hole at the top of the tank.
Can the fuel pump float (right one) rest on top of the hydramat?
