4
Not a waxer
michael everson
I wonder if you could just mount them in the inner holes on the frame?
Due to the 289 FIA's narrower track width the LCAs already mount in the inner set of holes, but even if that wasn't the case the pin drive lower arms are about 2" shorter so the difference between inner and outer holes wouldn't be enough to make up that difference.
