Thanks Thanks:  7
Likes Likes:  14
Results 1 to 40 of 53
Thread: Greg's '35 Hot Rod Truck
    Mar 2020
    Huntington Beach, CA
    This thread will cover my build and focus mostly on unique items that might help other builders. May of the other posts on this forum have helped me throughout the build with tips and ideas to make a truck that I am proud of. Thank you for all your great ideas!
    First the build description:
    • Factory Five ’35 Hot Rod Truck kit: Gen 2 Truck kit, Full fendered, Hood and engine side covers, Wilwood 12.88” front brakes, Koni Double Adjustable shocks, Electric power steering, 3 Link rear suspension, Ididit tilt steering column, Low Back Vintage Racing Seats (Kirkey), and Sound insulation kit.
    • BluePrint Engine package: 400 cu in Small Block Chevy, with Holley Sniper EFI (518 hp, 528 lb-ft torque), and TCI Automatic Transmission – StreetFighter 700R4
    • Rear Axle – Ford 8.8” from 2005 Mustang GT, with 3.31 to 1 gear ratio
    • Rocket Racing Hypershot Wheels: 18 x 8” front with 5.0” backspacing (added 1” spacer for more inner fender clearance) and 18 x 11” rear with 7.0” backspacing
    • Nitto NT555 G2 tires – 245/45 ZR18 front and 285/40 ZR18 rear
    • Wipers – Specialty Power Windows WWK-21, with bent stainless steel arms and flex blades for curved glass
    • Heater – Vintage Air Gen II with defrost
    • Final Body and Paint by Ken’s Custom Auto Body in Yuba City, CA (color is 2013 BMW LeMans Blue)
    Timeline:
    • Factory Five Kit ordered 1/18/2020
    • BluePrint Engine & Transmission ordered 1/18/2020
    • BluePrint Engine & Transmission delivered 3/12/2020
    • Factory Five Kit delivered 5/14/2020
    • Go Cart of the Chassis 12/3/2020
    • Delivered to Ken’s Custom Auto Body for final body work and paint 5/27/2021
    • Body and Paint Complete 11/12/2021
    • California Registration started 11/23/2021
    • California Registration completed 1/24/2022
    It has been a fun and rewarding journey!
    IMG_5090 - Copy.JPGIMG_5089 - Copy.JPGIMG_5088 - Copy.JPGIMG_5096 - Copy.JPGIMG_5100 - Copy.JPGIMG_5124 - Copy.JPGIMG_5122 - Copy.JPG
  2. Likes JR-FFR5011, RuffShod liked this post
    Mar 2020
    Front Bumper
    Front bumper to protect grill from curb damage. Includes structure that ties to front suspension bolts and to bottom of chassis. The under-chassis bumper structure provides a solid jack point under the front center of the vehicle.
  4. Likes Warped5 liked this post
  5. #3
    Mar 2020
    Reinforced Doors
    There were several gaps between the outer door skin and the inner door skin. Used panel bond to glue outer skin to inner skin where there were gaps. Also added fiberglass reinforcement inside door along door hinge line and door latch area.
    IMG_3034 - Copy.jpgIMG_3036 - Copy.jpgIMG_0181 - Copy.JPGIMG_0182 - Copy.JPG
  6. #4
    Mar 2020
    Transmission Tunnel
    Shaped and re-glassed transmission tunnel to provide room for 700R4 transmission but allow room for parking brake and seats. Also cut top front section off with grommets for 3 wire bundles. This allows wire bundles to be stay in place on the chassis while transmission tunnel can be removed.
  7. #5
    Mar 2020
    Kirkey Low Back Seats
    Used Kirkey low back vintage seats to maximize leg room (Tony FFR recommendation), then fabricated seat mounts that allow seats to flip forward for access under and behind seats.
  8. Likes chuck35truck liked this post
  9. #6
    Mar 2020
    Harness Bar
    Fabricated Harness Bar behind seats and eyebolts in floor for 5 point harness mount.
    IMG_3792 - Copy.JPGIMG_5021 - Copy.JPGIMG_5020 - Copy.JPGIMG_5132 - Copy.JPG
  10. #7
    Mar 2020
    Engine Side Panel Supports
    Fabricated engine side panel supports. Installed Ύ” steel tube under top edge of side panels, that anchor to the grill structure and to the firewall. This tube provides many benefits such as support to keep grill in place, minimize risk of hood gap changes, anchor for grill cowl and anchor for side panels.
  11. #8
    Mar 2020
    Engine Side Panel Cut
    Cut engine side panels under front control arm to enable easier installation and removal of engine side covers. Layed fiberglass matt on inside contour to provide means to bolt parts back together after installation.
  12. #9
    Mar 2020
    Engine Side Panel Vents
    Added vents to engine side panels to improve engine bay cooling. Reinforced side panels with 2 layers of 1708 fiberglass with epoxy resin. Cut 2 openings in each side. Bonded aluminum grill material to inside of covers behind openings.
  13. #10
    Mar 2020
    Hood Support Tube
    Fabricated hood support from Ύ” steel tube hinged at the firewall. There is a U shaped notch by the grill cowl to support the tube in the down position. When the hood is closed, the tube supports the center of the hood to remove sag (was about 1/2"of sag). The tube tilts up to support the open hood.
    IMG_3853 - Copy.JPGIMG_3857 - Copy.JPGIMG_3856 - Copy.JPGIMG_5005 - Copy.JPG
  14. #11
    Mar 2020
    Hood Quick Latch Fasteners
    Used Quick Latch fasteners on both rear edges of hood. This eliminated the floppiness of rear hood edges. Hood pins are solid mounted to a steel angle on the inside of the firewall, on top of the frame tube. It also retains the rear corners of the hood more precisely aligned with body lines. Cut a racquetball in half to use as a seal around latch pins, under cab front.
    IMG_3835 - Copy.JPGIMG_3827 - Copy.JPGIMG_3849 - Copy.JPGIMG_3851 - Copy.JPG
  15. #12
    Mar 2020
    Fender Reinforcement
    The fenders were very flexible and I was concerned that they would flex going down the bumpy road and crack the fiberglass. I was also concerned that rocks thrown up by the tires would eventually crack the outer gel coat. So, I reinforced the fenders in multiple ways.
    Added 4mm Coremat and 2 layers of 1708 biaxial fiberglass to inside of all fenders with epoxy resin. This made fenders much more rigid, reduces chance of cracking/fatigue, and reduces likelihood of rocks cracking gel coat (painted) surface.
    Front 2 bolts of front fenders are bolted into grill structure (tapped holes in aluminum). Bolts 3 and 4 from front of front fenders are bolted to stainless steel radiator supports. Bolts 6 and 7 from front of front fenders anchor to steel angle I fabricated to anchor fenders to chassis engine mount bracket.
    On rear fenders, fabricated tube to anchor bottom bolt of rear fenders to the chassis.
    IMG_4164 - Copy.JPGIMG_3994 - Copy.JPGIMG_4103 - Copy.JPGIMG_4087 - Copy.JPGIMG_3990 - Copy.JPGIMG_4085 - Copy.JPGIMG_4084 - Copy.JPGIMG_4005 - Copy.JPG
  16. #13
    Mar 2020
    Fender Braces
    In addition to beefing up the fiberglass and mounting points, I used stainless steel strap to reduce fender vibration. One on the tail of rear fender to bed side, using weld mount stud on inside of fender. One on the side of the front fender behind the wheel to the engine side cover, using weld mount stud on inside of fender. Second on the top forward of the front fender (near the headlight) to chassis, using weld mount on underside of fender.
  17. #14
    Mar 2020
    Running Board Steps
    Fabricated aluminum running board pads. They are powder coated with hammertone finish to provide a durable surface that doesn’t show scratches. The hold down bolts are countersunk into the aluminum and allow anchoring the fiberglass running boards to the chassis running board support structure.
  18. #15
    Mar 2020
    Battery Access Door
    Provided battery access door in bed. Cut a door from the stainless steel floor and installed it with a hinge and Quik Latch fastener.
  19. Likes chuck35truck liked this post
  20. #16
    Mar 2020
    Front Bed Panel Gap
    Resolved front-bed-panel gap to bed sides. Fabricated a Ύ” angle that bolts to the front panel and to upper angled bedside.
  21. #17
    Mar 2020
    Tailgate and Backup Light
    Bolted tailgate closed to remove unnecessary hinges and latch hardware. Fabricated 1-1/2” stainless steel strap to close gap on inside of tailgate to bed sides. Fabricated 1-1/2” angle for top edge of tailgate for finished look.
    Installed a license plate frame (center mounted) with a built in backup light.
  22. #18
    Mar 2020
    Windshield Wipers
    Installed windshield wipers. Motor is mounted high up behind the dash on the passenger side. Wipers are bent stainless steel with wipers for curved glass.
  23. #19
    Mar 2020
    Foot Box Kick Panels
    Fabricated aluminum kick panels inside cab to cover frame and body near hinges. Significantly reduces hot air from engine bay. Also provides anchor point for door check straps.
  24. Likes FF33rod liked this post
  25. #20
    Mar 2020
    Door Sills
    Fabricated aluminum door sills to cover edge of body and top edge of carpet. These are different than the FFR sills which required cutting much of the body fiberglass flange to install.
  26. Likes FF33rod liked this post
  27. #21
    Mar 2020
    Center Console
    Fabricated a center console between the vintage racing seats. The console continues forward for gear shift indicator, window switches and auxiliary switch panel. Due to the width of the vintage racing seats, the console had to be pretty narrow.
  28. #22
    Mar 2020
    Steering Shaft Relocation
    Steering shaft relocation to improve U-joint angles and eliminate notchy steering. Additional U-joint added between firewall and frame, along with Heim-joint support to reduce U-joint angles. This works okay for me, but if you have large feet, the shaft between the accelerator pedal and brake pedal could interfere with moving your foot from one to the other (use caution with this mod).
  29. #23
    Mar 2020
    Driveline to Frame Clearance
    Frame notch for driveline clearance. At bottom of hoop in rear of cab, cut Ύ” out of the horizontal tube under the driveshaft. Smoothed transition with fiberglass and epoxy. Reinforced cut section by adding heavy SS strap under the tube section I cut away.
    IMG_4365 - Copy.JPGIMG_4379 - Copy.JPGIMG_4380 - Copy.JPGIMG_4383 - Copy.JPG
  30. Likes Pat Landymore liked this post
  31. #24
    Mar 2020
    Resonators Behind Mufflers
    Resonators installed behind mufflers to reduce loud harsh exhaust and improve exhaust tone. Used Vibrant Ultra-Quiet Resonators with 2-1/2” inlet and outlet. Cut existing exhaust tips and inserted the resonators into the exhaust tips to keep the ball end mount and turndown tips.
  32. #25
    Greg,
    Congratulations on your gorgeous truck and thanks for your fantastic write up. I’m sure we will be seeing many of your great fabrication projects popping up on builds that follow. Great work.
  33. #26
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    Hello Greg:
    Your build of the truck is fantastic…you’ve shown us so many original ideas👍🏼👍🏼
    Congratulations on a super job!
    Once again with an 88 mm Turbo, Big Block Chevy powered, ‘35 Hot Rod Pickup
  34. #27
    Mar 2020
    Greg,
    Steve,
    Thanks for the feedback. It was a very fun project and I learned a lot from others on the forum. I thought this post might help pay it forward with ideas for others.
    Greg
  35. #28
    Mar 2020
    Hello Pat,
    Thanks for the feedback, and especially thank you for all your posts. You have a nice truck and a nice build thread. I read them in detail to gain ideas for my own build.
    Greg
  36. Thanks Pat Landymore thanked for this post
  37. #29
    Senior Member jayguy's Avatar
    Las Vegas
    Beautiful truck! I like all the mods and additions you did too, very smart!
  38. Thanks Sbda4 thanked for this post
  39. #30
    Senior Member Robodent's Avatar
    Aug 2018
    Hampshire, IL
    Greg Beautiful build ! Thanks for sharing your mods. I really like your seats and center counsel beautiful job. That’s going to be a modification I’m going to do on my truck down the road for me . Thanks for the pictures and ideas you created for others. Rob
  40. #31
    Mar 2020
    Quote Originally Posted by Robodent View Post
    Rob,
    I see you post often and appreciate all the info I get from you and others. Thank you!
    Greg
  41. #32
    Great Job!
    16+ FFR kits and counting!
  42. Thanks Sbda4 thanked for this post
  43. #33
    Mar 2021
    Bradenton, FL
    Beutiful! Thanks for all the pic's. Will be very helpful for me. Thank you!
  44. Likes Sbda4 liked this post
  45. #34
    Sep 2019
    Houston, TX
    Very nice and thanks for posting!
  46. Likes Sbda4 liked this post
  47. #35
    Senior Member ztoolman44's Avatar
    Apr 2019
    Summerland, BC
    Quote Originally Posted by Sbda4 View Post
    I just cut that entire piece out of my truck today. I will be fabricating a new drive shaft hoop down the road. Thanks for the tips and tricks.
  48. #36
    Mar 2020
    That is certainly a viable option. I already had the chassis and body work mostly done before i realized that driveline clearance was an issue. So I did a minimally invasive approach. If I was earlier in the build, cutting the tube out completely would be a pretty good option.
  49. #37
    Aug 2019
    Alvin, Texas
    Is your rear suspension on high or low setting?
  50. #38
    Mar 2020
    I used the lower holes for my suspension to get a higher ride height. This is recommended for the trucks, but I found necessary for full fenders. It does create a challenge with driveline clearance near the floor at the back of the cab.
  51. Thanks RuffShod thanked for this post
  52. #39
    BluePrintEngines's Avatar
    Nov 2015
    Kearney, NE
    Hello Greg,
    Congratulations on this stunning build! We greatly appreciate the build thread, and pictures! Can we share this pictures on our social media? I cannot thank you enough for choosing BluePrint Engines!
    Thank You, Jose
  53. #40
    Mar 2020
    Quote Originally Posted by BluePrintEngines View Post
    Hello Greg,
    Thank You, Jose
    Jose,
    Thanks for the post. Yes, you can share the pics on BluePrint social media. The SBC 400 and 700R4 have been a great choice. I can’t say enough good things about the support I’ve received from BluePrint with some technical questions. Johnny and Josh have always been quick to provide support.
    Greg
