20
87
Mark Eaton
Is that 6 spd transmission the same width as the 5 spd? Im just wondering if it will affect the length that the CV axle needs to be? After all the issues I'm having trying to find a replacement CV joint for my 818 I am very tuned into this issue!
The 6 speed is wider, taller, longer and heavier than the 5 speed. It does not effect the axles though. The FFR design has plenty of room for lateral movement and slight variations in transmission width and placement. I used the FFR axles in both my original 5 speed and this 6 speed.
