Finishing Touches
While waiting for spring I made some finishing touches to the car. I added an on board fire suppression system and finally cut the rear deck to fit the Honda motor.
Here is an overview shot with the seats out so you can see the fire suppression system and notched out rear deck lid.
There are three output nozzles for the Halon fire system. One points into the passenger compartment between the driver and passenger. There are two more nozzles in the engine bay. One on the exhaust side and one on the intake side. I designed it so that the entire system is attached to the aluminum firewall bulkhead pieces. This makes removal easy as taking out the firewall also removes the fire system without having to take it all apart.
IMG_20240214_093059885.jpg IMG_20240214_094007712.jpg IMG_20240214_094031358.jpg IMG_20240214_094043521.jpg
The rear deck lid needed 1.75" notched out between the rear humps to give enough clearance for the top of the motor to poke through.
Post Thanks / Like - 0 Thanks, 3 Likes
