Quote Originally Posted by cc2Arider View Post
Another quickie inside-the-house project was to assemble my coil-overs:
Recommended zip-ties...
Craig C
Hey Craig, just curious when you put your coil overs together, did you check the setting on each shock? I had three set at the #1 setting and one at #2 setting. I changed them all to the #2 setting. Many don't know that the Red Koni's are actually adjustable.
Ted
