Thread: How to fill holes in the firewall?
    Sep 2022
    Huntington, IN
    Any y'all filled unused holes AKA: mistakes? How or what do you use to fill in unused, unwanted holes? I was thinking JB Weld or some kind of aluminum patch? I'm looking for suggestions here. Thanks
    How big are the hole(s)? Regardless, I probably wouldn't use JB Weld. For small holes, a polished (SS) round head screw looks decent and gives the impression it's there for a reason. Larger holes, I'd probably go with a patch. I get it. Everyone likes a nice firewall on the hot rod (or truck) and especially if not installing a hood. But keep in mind, once done, it's relatively busy and much of the view is covered or at least obstructed by the engine and related.
  3. Likes Just 1 More liked this post
    Sep 2022
    Huntington, IN
    2 holes are 1/4" or 5/16" and the other is around 1/2". I thought about the stainless bolts for the 1/4" but the 1/2" one i'm not so sure of, Though maybe a simple rubber plug. BUT, like you said, once it's all done, I doubt it would be noticable.
    How about panel/hole plugs or sealing grommets? Lots of sources and sizes available.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Senior Member ydousurf's Avatar
    Feb 2019
    Greality, Colorado
    J1M, ebay has many options from rubber to steel. There are metal polished one's w/clips that just push-in and you're done.
    Doug
    Dj or Doug or TheLateDude
    ----- #19 of 25th Anniversary MKIV 9769 -----
    Build Link: https://thefactoryfiveforum.com/show...-Slow-Progress
    Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
    Kingsland, TX
    I had a measurement mistake and drilled a couple holes in the wrong place. Thankfully I know a few friends with TIG welders and asked one of them to weld up the holes for me, then ground them smooth.
    Jun 2018
    North Vancouver, BC, Canada
    I threaded the hole and put a screw in it Didn't make a mistake with a bigger hole but would use a plastic or rubber hole plug if needed.... many different brands, some on Amazon even.
    Gen 1 '33 Hot Rod #1104
    Sep 2022
    Huntington, IN
    Didn't even think of the metal hole plugs, going to stop by my neighborhood hardware store and see what they have. Thanks guys
