Sorry for posting in the wrong place
Learning
Learning
The Windy City boys are seriously moving forward to determine our order. My son and I are welcome to all your tips, and ideas both for the orginal order and all the interesting ideas and modifications you have made for yours. We will order the full kit. We are looking at 400-450 hp engine from forte or engine factory. Please feel free to send me anything and everything. I would greatly appreciate it or.. direct me to the threads you think worthy of looking at. Remember anything and everything. Also we are 6' and 6'2" so foot space is a "hot" topic.. but really anything. We did take the build class Dec '11. All your help, experience and advice would be greatly appreciated..
newbie here. just starting to look for a donor car and getting to learn from the threads. found a car that is not starting but seems cheap but still have to do research if the vin is provided to me by the seller. 2000 GT 4.6 automatic 81k miles garage kept. seller claims has no clue why the car is not starting despite having "many new parts". not thrilled with the automatic so how much woud switching with a manual set me back if I had to. do automatic transmissions sell in the used market?
my thought is to invest in cheap donor first and the dive in to order the kit when I have a better handle on how much more I have to buy away from the donor.
appreciate any thoughts.
given the welcome message - should I go for an 818 instead for something more manageable?
thanks.
Hi. I am considering buying a mk4. I am fairly mechanically inclined but necessary in auto. I have messaged factory five and they don’t seem to think assembling one should be a problem. I have watched a few YouTube videos and browsed the manual and it doesn’t look too intimidating. I would like other builders opinions on the difficulty of the build please.
Appreciate the response. Can I ask what all u used for engine drivetrain and how difficult that part was?
In case he doesn't see your post I'll answer for David---the pads like shown on the blue car were produced by our friend Cobra Earl and are out of production. You might turn up an unused one by posting a "want to buy" in the classifieds. Heck, it might be worth sending Earl a PM on the off chance that he has some old stock.
Hi guys,
I am going to be mounting the brake reservoir today and wondering where people mounted it in there car? Here is a photo of the one I am using.
are you going to use one or two reservoirs? are you running a cable or hydraulic clutch? many use a triple reservoir setup (2 for front/rear brakes and 1 for hydraulic clutch) and mount it to a bracket attached to the 3/4" tube just in front of the DS footbox wall. you want to make sure the top of the lid is below the 3/4" frame for hood clearance issues and that you don't place your bracket/reservoirs too far in front of the footbox to avoid issues w/ the hood struts. CNC used to make a double/triple reservoir but they went out of business. Contact Mike Forte, I think he has some aluminum billet triple reservoirs for sale. I have an unused stock FF brake fluid reservoir like in your pic if you want to run a double reservoir and want matching units. I just have the reservoir and none of the mounting brackets. FF sells the whole kit for $62. make me an offer if interested.
Just one reservoir for front and back and I am running a cable clutch. Thanks for the advice on where to place the brake reservoirs, I think I will use one for now and see if I need to upgrade later down the line. Have a good weekend
Tomorrow I am going to start on the wiring harness and the dash. Any advice that you guys can give me to make the process go smoother and make the dashboard look professional?
This is the wrong forum.
Most of us mount it on the 3/4 tube in front of the driver's footbox.
Remember that the top of the reservoir must be above the master cylinders.
Just make sure it doesn't interfere with the body or hood and you'll be fine.
https://youtu.be/_wnHDNgnNqs
Welcome Aboard From The Dark Dart Side!
