Picture is here:
https://www.facebook.com/photo.php?f...type=3&theater
Observations, not critiques.
Stock seats. The donor must have been a WRX TR model as I beleive that's the only trim (in '06) that had the separate headrests.
Coolant tubes run outside of frame. Looks like hot and cold on seperate sides.
Long shifter cables that run forward from the shifter and then around the frame and finally to the back of the transmission.
Fuel tank behind the seats as evidenced by the large silver filler cap. (critique: Put it on the passenger side like all proper Subarus!)
Long extension spacing the turbo away from the factory downpipe. They normally bolt together. I'm guessing that this is a temporary heat management solution so the gocart can be driven without melting close-to-motor stuff. A final exhaust will come with a final body.
Factory instrument cluster looks like it's just sitting on the frame waiting for a fiberglass dash to call home.
Picture is too dark and too low resolution to check for H6 compatability (likely as intended)
So far, I don't see anything that would exclude most other Subarus as donors. A cable clutch being the biggest hurdle for older cars.
