Jeff,
If the Turbos were placed lower than the GN had, the heat would not be that big of a problem.
Its doable, and I think it would be a modification that would really put the performance over the edge!
Hank
Jeff,
Hank
“If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
