0
0
Originally Posted by
PhyrraM
You mean ugly, stamped steel control arms. I've seen "online" (whatever those are worth) weight quotes between .5 pounds per side to 1.7 pounds per side.
In any case, definitely not cast iron....but I assume you knew that and just typoed.
Sorry haha, not a typo but maybe a brain fart. Regardless, the '06 has the nice aluminium ones, all other years have the ugly STAMPED STEEL lower control arms which are a real PITA to work with. There are few pitman arm pullers that fit over them when you want to pop the ball joint out for a quick fix. I've been in rusted ball-joint hell with my outback for a while and literally had to saw through the left ball joint that was rusted and sized into the arm and into the knuckle. If it had the nice aluminium ones, a pitman arm puller would have popped it out no problem.
For that alone, it's worth it if you ask me lol.
