Page 6 of 7 FirstFirst ... 4567 LastLast
Results 201 to 240 of 251
Thread: The Grassroots Motorsports 818 Build
  1. #201
    Quote Originally Posted by Silvertop View Post
    Yes, very much an improvement. But those recesses could impact the placement of stereo speakers in the doors. What is the vertical dimension and depth of the upper recess? Anyone at Grassroots care to measure?
    I'm sure they'll come up with a "caption this photo" for you.
  2. #202
    I think it will be fine... looks like you still have several inches in the bottom and pretty much the whole depth at the top.
  3. #203
    Senior Member Silvertop's Avatar
    Forest Lake MN
    I think it will be fine... looks like you still have several inches in the bottom and pretty much the hole depth at the to.
    I think you are quite right about the depth. The doors are plenty deep enough for even the very best speakers. But because its an open car with lots of wind and road noise, for adequate volume and sound reproduction, I will want to mount my speakers as high as possible in the doors -- which means installing in the upper recess. And because I don't want to take up precious and limited space in the car with a subwoofer, my plan was to install the largest and highest quality coaxial or three-way speaker I can buy. The goal is a really good 6 X 9. But there may not be sufficient vertical space (at least 6") in the upper recess. Which means I may need to go smaller -- which will cost me some bass response. Or get really creative with the speaker mounting process...... In any event, that's why I'm concerned about the vertical dimension of the upper recess. Hopefully, GRM or someone else who has the new door panels will be able to measure the recesses and post the results. If not -- well, my kit will probably be delivered next week. If the new panels are included and not backordered, I'll be able to measure them myself. But that's a big if............. !
    Apologies for the thread-jack. I know there is a more suitable thread for discussing stereo systems. I won't discuss that any more here. I just need to know the vertical dimensions and depth of the new inner door panel upper recesses.
  4. #204
    Encinitas, CA
    That would be the thread I started here. I"m in the same situation, I will be installing an audio system, and am anxiously looking for any info on mounting options in the door panels.
    my plan was to install the largest and highest quality coaxial or three-way speaker I can buy. The goal is a really good 6 X 9. .
    FYI, for sound quality forget about coaxial speakers or most 6x9's!!! Get a good set of component speakers (with separate woofers, tweeters and cross-overs network). This lets you mount the tweeter higher in the door for better stereo imaging. The woofer, which handles harder to localize low frequencies, can then be mounted lower in the panel without issues. There are lots of quality component systems with 5.25" and 6.5" woofers (and some 6x9). If 6.5" doesn't fit, I'm optimistic there will be a good location for a 5.25" (but that would likely require a sub for decent bass).
    Let's move any further discussion over to the audio system thread; I wanted to make sure to point it out here so it wasn't missed.
  5. #205
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    ^What he said!
  6. #206
    Forest Lake MN
    Agreed. Shifting this conversation to the audio thread. But I'm still hoping someone gets us a measurement on the height of that upper recess in the inner door panel! Wouldn't mind a vertical and horizontal measurement on the space directly in front of that upper recess (toward the door hinges) as well.
  7. #207
    Member GrassrootsMotorsports's Avatar
    Holly Hill, FL
    Hi Guys, we have been out all weekend at Sebring (Yellow Miata):
    What a great time, and was great to meet Wayne from VCP!
    Also, look what I found in front of our office this morning:
    Finally got to go for a test drive, I really enjoyed it. Great, fun car!
    I also found a tape measure in the midst of all the fun:
    The only place to logically mount a speaker is in that indention in the middle of the door panel. The indention measures approx 20" wide by 6.5" tall. It is recessed 2" into the door panel. I see no issues mounting a 6.5" round or 6x9 speaker in that space.
    I will have more photos from the build soon, hopefully later today.
  8. #208
    Cape Cod
    Caption, My first thought was....."woo look, no panties".
  9. #209
    When am I ever going to get to work on my own car?
  10. #210
    Forest Lake MN
    Quote Originally Posted by GrassrootsMotorsports View Post
    Thanks for the comeback on that. It's much appreciated. But for clarity, are those the dimensions for the upper or lower indentation/recess? If it's for the lower, I would really appreciate a measurement on the upper as well. At minimum, I'd like to at least put a tweeter in the upper........
  11. #211
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    So very true....
  12. #212
    Holly Hill, FL
    The upper indention measures 26"x5" and isn't recessed enough for measurement. It is very slight. Basically I envision a tweeter mounted in this spot then a regular speaker mounted in the lower indention. If you guys have any other questions or need pics of things just let me know, as the 818 should be in the showroom for a week or two.
  13. #213
    Forest Lake MN
    Thanks for the clarification. While I was hoping that the upper recess was the 6 1/2" number you quoted, I figured it wasn't. Just looked too small. I'll probably stick a component set in the doors with a 6 1/2 in the lower recess and the tweeter up high. It'll work. Thanks again.
  14. #214
    Holly Hill, FL
    ^Not a problem!
    Putting some finishing touches on the front end:
    Interior finishing:
    Studs for the rear "hood"
    We painted the stock wheels black, for now.
    Caption this photo!
  15. #215
    Forest Lake MN
    Actually, I did think of one more question relating to the door indents/recesses.......... Do you have any idea how much depth there is in the door BEHIND the lower recess? Based on the photos, there appears to be a fair amount. Hoping for about three inches at minimum......
  16. #216
    I bought lunch last time. It's your turn.
  17. #217
    Freeport, ME
    I told you no more chile from La Comida el Volcan for lunch!
    Dan
  18. #218
    Senior Member NicksPapaw's Avatar
    Knoxville TN
    Caption this photo!
    [/QUOTE]
    If I told you once, I told you a thousand times. When I am on my knees, I am looking for clearance issues in the wheel well. I am NOT sniffing your crotch!
    MK 3.1 #6422, Complete Kit, 340hp Ford Racing Crate Engine, WC T-5 Trans, 3.55 Rear, Barcelona Red Mica Metallic, Silver Stripes
  19. #219
    Holly Hill, FL
    Not sure on exacts but there is definitely room between the door and door panel to fit a speaker.
  20. #220
    Forest Lake MN
    Thanks. That's really all I need to know. I can be happy now.
  21. #221
    Banned
    Aug 2011
    No, who's on first, what's on second!!!!DSC_3919_zps150423b7.jpg (no one under thirty will probably get this.)
  22. #222
    Holly Hill, FL
    After completing the build, we weighed it:
    Then it's test drive time. But first, we needed some gas:
    And away we go:
    We have the car back in Florida and all is well. Many thanks to Wayne for helping us out on the build. We all had our fun test driving it last week, and now the car resides in our showroom. Up next, the car will be getting a vinyl wrap and hitting the track for some baseline tests. I will keep the thread up to date as we do things with the car.
  23. #223
    Holly Hill, FL
    Caption this photo
  24. #224
    Clovis, Ca
    Are you going to cut open the side vents?
    Thanks- Chad
  25. #225
    Holly Hill, FL
    Yes, after the car is wrapped.
  26. #226
    Huntsville, Al
    Caption this photo
    3 guys standing around...one guy working....I didn't know VCP was a gov't operation,......
  27. #227
    Where did our dash go? I thought that last cardboard box was empty when you threw it out?
  28. #228
    Senior Member D2W's Avatar
    Spokane, WA
    Over 1900 lbs on a donor build with bare bones interior and no gas. Kind of disappointing but expected after what the car weighed at the open house with aftermarket brakes and seats.
    I can do anything with enough time and money.
  29. #229
    Administrator
    Enterprise Alabama
    Quote Originally Posted by D2W View Post
    The stock seats with seat heaters and airbags are HEAVY!!!!!!!!!!!! Would not surprise me if they were over 60 lbs each
  30. #230
    Feb 2013
    Bowling Green OHIO
    Wayne, so you got the stock seats to fit..... thats good news, i was sceptacle. i have 2006 wrx wagon limited leathers heated i wanted to use but have read all the fuss about getting the seats to fit. glad to know someone has fitted them.
  31. #231
    Administrator
    Enterprise Alabama
    Caption this photo
    Sorry guys, I should not have eaten that burrito for lunch...
  32. #232
    Senior Member Geoff H's Avatar
    Edmonton, Alberta
    lol!! That one fits perfectly Wayne! The look on the guy's faces says it all. Were you crop dusting while working??
  33. #233
    Freeport, ME
    Quote Originally Posted by dougkirkbride View Post
    Wayne made his own mounts for the GRM car... I just got my stock seats in mine using their new mounts. They could lower them an additional inch tho... At 5' 8" I fit fine with the new mounts. See photos on my thread
    Dan
  34. #234
    Kitchener, ON
    Is there a safe way to remove the seat airbags?
  35. #235
    Freeport, ME
    Yes! Just did mine today. Flip the seat over and unzip the back panel. the panel tucks underneath with plastic clips. Carefully pull the wires through the space between the seat pan and the back. The wire is held to the pan by tape, just tear it away. Next cut/remove the two hog rings holding the side panel of the seat tight. Remove the two nuts and you can pull the airbag out. Fill in the space with some stiff foam. Either replace the hog rings or use a couple tie wraps to hold the side panel tight. Zip up the rear panel, re clip the panel at the bottom...
    Done!
    Dan
  36. #236
    Kitchener, ON
    Done!
    May I ask how much they weigh?
    2003 Corrola, stock with custom Fe2O3 coated fenders.
    2015 FFR 818 (get PhD-> get real job-> get 818)
  37. #237
    Freeport, ME
    sure, give me another job to do! :-)
    I'll have an answer for you soon, I'm guessing 2-3 lbs each...
    2lbs, 4 oz with my postal scale
    Dan
  38. #238
    Holly Hill, FL
    Senior Member gwader's Avatar
    Torrance
    Thanks for the great vids!
  40. #240
    Administrator
    Enterprise Alabama
    Uggg, the clutch video. Nobody could have told me I rubbed my nose with a dirty hand???
