Finished the front brake lines today. Only had to flare one line. I wanted to make it as clean as possible.
This short run was a little challenging and finally gave in and did it by hand.
The mounting collars that came with the braided lines worked great with the larger clips when mounting to the uprights. As with the rear I was able to put the extra hardware to good use.
