sounds great Gene....
I can't believe YOU didn't tighten a hose clamp...so,,,, was the go-karting enough of a rush to get you past the paint funks???
that's exactly why I am prone to staying away from the ISIS system... I can't seem to justify the "gizmo factor" over good old tried & true switches...
looks like you will be on the finishing touches just about the time the weather is getting right for cruising....
