Put me down for the shift rod and bracket. Thanks
Thanks- Chad
Steering column spacers arrived today. I'm talking to David Hodgkins right now about getting my Vendor status. The other two parts should be here this week.
Put me down for a steering rack spacer. Can you write up a little something about how you pressed your column down? My 12ton isn't tall enough to get the column under it. I just used a lump hammer on my bad column, but not sure that's the best method.
Put me down for 1 steering bracket
Add me to the list for the spacer.
Add me to list for steering column spacer
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
Have you seen the 818 Registry on Google Maps?? https://www.google.com/maps/ms?msid=...a=0&dg=feature
Want your 818 added to the Registry? https://docs.google.com/forms/d/1zmF...rNCY4/viewform
Getting closer.
Shift Arms:
Next product will be radiator spacers.
They have a machined lip on the inside to retain the stock bushing:
And attach through the frame using a large washer and button head screws:
Can't wait for my shifter arm and bracket. The shifter arm looks awesome.
Thanks- Chad
Oh no! More shiny stuff to make me crazy. I hope my name is on one of the steering column spacers and one of the shifter arms. Are you a vendor yet?
Please, please take my money!
Pete
I like your radiator spacers.
Zero Decibel Motorsports
Which one has my name on it?
Cable brackets arrived. Going to start sending PM's to the list of interested parties. It looks like this first round will be a sellout.
Sent mine, too!
818S - #67 (SOLD IT!)
Delivered: 18 November 2013
Go Karted: 29 December 2013
Finished: NEVER!
I also paypal'd my money and now looking forward to the goodies.
A guy can buy a cool kit and then invent and make a few parts that others like so they help pay for the kit. What a cool country, eh?
<---Payment sent as well.
Agreed with Pete.
I have a few parts left that are unpaid for from the original group. I'm offering them to the next in line. Once these are sold out I will reorder another batch. Thanks everybody for your support.
Thanks Rori, tracking says it will be at my front door when I get home so I'll get it mounted up tonight and post my results.
Hoping to take about 60mm out of the column.
Received mine today. Fast shipping and packaged neatly. Thanks! Look forward to seeing the next parts you design.
Very nice Rori. Just installed, quick writeup:
http://thefactoryfiveforum.com/showt...l=1#post150494
Rori,
Did I see some where that your shifter hardware only works with the KTune shifter or will the they work with the shifter box and cables supplied from FFR?
I have only tested it with the K-tuned parts. I no longer have the FFR bracket to even test it with. It would probably work if you pointed the arm down and flipped it around, but because you can't bend the arm like you are instructed to with the FFR arm it may negate any clearance that you were hoping to gain.
The first batch of shift arms and cable brackets are sold out. I'll be reordering all 3 pieces on monday.
Got my shifter arm and cable bracket... look great, thanks!
Put me down for a steering spacer please. Pm me with availability. Thanks you
Just got my column spacer, very nice thanks Rori.
Got my shifter arm and bracket as well. They look great although I won't get to installing them for a couple of weeks.
Larry
Got back from a trip last night and the part was sitting there waiting for me. Looks great. Thanks.
Thank you, everything looks great
Anymore steering brackets available? PM sent
does it replace something supplied by ffr or from the donor? or is it an add-on part
Most of the frames I've seen, the radiator isn't high enough so the steering rack bellows rubs the coolant hose line. Some people have made their own spacers to move the radiator up so it doesn't rub. Rori has a nice solution that is simple but effective.
