My thought in making them was to offer them, same goes for the canards. Ultimately I would like anyone to be able to replicate the car we built if they want and then share set-up data back and forth as I think that is what really gets the car to the next level track time wise.
If people want them please speak up and I can get them into production, if not I can probably at least get a few sets done.
FYI this is the set-up we used:
Front:
Ride Height 3.25 inches
Toe: 1/16 inch total toe in
Camber: -2.5 degrees (had to trim the upper arm just a bit to get this much)
Caster: +3.5 degrees (manual steering, although we are going to test power with 5-6 degrees next time)
Production "R" springs and shocks
No sway bar but also may test the bar again to see if we like it at the higher speed tracks
Rear:
Ride Height: 3.5 inches
Toe: 1/4 inch total toe in
Camber: -3.0 degrees
Roll steer set at zero (both lower links parallel)
Suspension and Brake Components:
2006 aluminum front lowers with Beatrush heim joint Anti-lift kit
Whiteline poly bushings on front lower arm and rear trailing arm at spindle
Adjustable rod end lower transverse links (all 4 rears)
Rod end adjustable lower trailing arms
Wilwood 13 inch front brakes
Wilwood 12 inch rear brakes
Rota Torque 17 front and 18 rear wheels
Yokohama Advan Slicks 210 front and 240 rear
