Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 393
Thread: nkw8181's 818 build thread
  1. #201
    QC, Canada
    Bob it does load very slowly. Probably the number of pictures along with the host site they are hosted at.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  2. #202
    QC, Canada
    how did you deal with the gap at the bottom (floor) since its like a 1/4 short now ?
    I actually add gap to my alu cover, as it was not 100% sitting on the frame and it was erratic on the foot floor too. Besides, I will fill that gap on the floor with undercarpet or other stuff that add a gap anyway.
  3. #203
    nkw8181's Avatar
    Dallas, TX
    Frank do you have the Boyd tank? I heard that it would be difficult to run the lokar since the cables are suppose to mount from underneath.
    Tony,
    There isn't anything "wrong" with thw way F5 shows it I just didn't like how high it was and wanted it horizontal.
    Frank mine is that close because I made it horizontal. How are you going to mount you cables if you don't have the metal ends with any configuration?
    Nolan
  4. #204
    nkw8181's Avatar
    Dallas, TX
    Like Frank that is where mine sat. Debating what to do for the front floor. Considering welding some tabs of angle iron to the front floorboard to use as mounting points so I don't rivet to the floor.
    Nolan
  5. #205
    QC, Canada
    Quote Originally Posted by nkw8181 View Post
    Bingo! When I read this and the encouragements of wleehendricks it made an explosive mix in my head. Couldn't think of anything else but that installation.
    So I mocked it up. Shifter and ebrake, OEM. It's close but it doesn't annoy my shifting at all. In fact I plan on mounting the handle under the small tunnel tubing, instead of over it.
    But like you said, that's not my problem! My problem is I still can't bolt the cables in place. I have a few ideas but I am missing that cable bracket and I can't recall it being on the donor, if I recall the brackets were welded onto the chassis on the tunnel. Anyway pix of what I mean on my thread and a taste of solutions to see what you guys think.
  6. #206
    nkw8181's Avatar
    Dallas, TX
    So I'm thinking of welding the brake line tabs to the frame. Any reasons I shouldn't? also is there an easy way to get a fifth one since I will need one for my clutch hookup or is the only option to make one? I have .125 thick scraps but looks to be the tabs are ~.100.
    Nolan
  7. #207
    nkw8181's Avatar
    Dallas, TX
    Did a bit more welding. Want to mount my center tunnel to the side rather then the floor. also these angles give me somewhere to mount speakers if I chose to later.
    Nolan
  8. #208
    nkw8181's Avatar
    Dallas, TX
    I installed countersunk screws in all my rivetnuts to prep for powder coating
    Nolan
  9. #209
    nkw8181's Avatar
    Dallas, TX
    Woooo hoooo and it's off to get purrdy via powder coating. Now what should I do without the frame....... Hmmm anything on the body that I should start with?
    Nolan
  10. #210
    nkw8181's Avatar
    Dallas, TX
    Wooo hoooo the frame and aluminum panels are back from the power coater and look great!
    Nolan
  11. #211
    nkw8181's Avatar
    Dallas, TX
    Now to build for real!
    Nolan
  12. #212
    QC, Canada
    Darn nice! Great job!
    Any close-up pix on some bars, like the roll bar and some big square ones?
  13. #213
    nkw8181's Avatar
    Dallas, TX
    Headed on a cruise but I'll get some better pics for ya when I get back and start building again
    Nolan
  14. #214
    nkw8181's Avatar
    Dallas, TX
    So life got busy but I finally got some progress to show. I got alot of the panels installed this past weekend. You can see the powder coat better as well even though it is dirty.
    http://imgur.com/a/SEUyi
    Nolan
  15. #215
    nkw8181's Avatar
    Dallas, TX
    Thought the link would work
    Nolan
  16. #216
    Mechie3's Avatar
    Indianapolis
    Link works for me.
    Zero Decibel Motorsports
    Check out my new website!
  17. #217
    Aliso Viejo, CA
    Dude, at first I thought you drilled out all your sheet metal for weight reasons... then I realized it was the mat under the car. LOL.
  18. #218
    nkw8181's Avatar
    Dallas, TX
    Ha ha ok that is pretty funny lol.
    Nolan
  19. #219
    nkw8181's Avatar
    Dallas, TX
    Finally got an update. I'm in the midst of prepping to move. So I'm hoping I got the front upper a-arms mounted right. Can I get a double check. Also all the front panels in can install are installed.
    http://imgur.com/a/nZVfh
    Nolan
  20. #220
    Senior Member TouchStone's Avatar
    Sep 2014
    Dallas, TX
    According to Wayne http://thefactoryfiveforum.com/showt...l=1#post111559 you did it right. According to the manual, even in the latest revision 1O it is very unclear. Mine are currently the other way, which is good indicator that your correct.
    818S Chassis #288 2.5L 323hp
    Ordered: 9/19/14 Received Kit: 11/2/14 First Start: 5/31/15 First Drive: 6/7/15 Registered: 3/10/2016 Completed: 2/10/2017
    Status: Complete Build Thread Sold 9/22/2017
    joshuajach.com
  21. #221
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Quote Originally Posted by TouchStone View Post
    Now that is funny!
  22. #222
    nkw8181's Avatar
    Dallas, TX
    So long as we are clear who is Wright
    Nolan
  23. #223
    nkw8181's Avatar
    Dallas, TX
    Making more progress bit by bit. Spent time grinding of the sway bar mounts painting my rear later links only to realize that one had a bend in it. So I ordered Waynes kit. I'm moving the car this sat to the new house so the pressure is on to be a roller again.
    http://imgur.com/a/5PD9J
    Nolan
  24. #224
    Feb 2014
    Asheville, NC
    Looks good! I love the painted aluminum panels everywhere with the contrast of the silver rivets.
  25. #225
    nkw8181's Avatar
    Dallas, TX
    Thanks, I found it didn't cost much more to have the aluminum powder coated along with the frame.
    Nolan
  26. #226
    nkw8181's Avatar
    Dallas, TX
    Got the car moved to the new place. I will say it is a pain to move a half built car buy got it done! I also got new brakes and rotors installed (and they are pretty!). As well as the turbo switched out for the 20g I picked up. Man there is a definite difference in size. Got the clutch Blead no problem but the brakes won't build pressure. I posted this in the brakes forum and was told that since the master cylinder was dry it may take a while to get bleed. The upper a-arms look like they may indeed need trimming. I have positive camber and not a little. Also the caster looks pretty high.
    http://imgur.com/a/14rL2
    Nolan
  27. #227
    Mechie3's Avatar
    Indianapolis
    Do you have an early kit? Early ones with the tilted top mount for the ball joint need to be trimmed on the driver side.
  28. #228
    nkw8181's Avatar
    Dallas, TX
    Just the driver side? The passager is the same. Kit 187
    Nolan
  29. #229
    Administrator
    Enterprise Alabama
    He has the flat ones.
  30. #230
    nkw8181's Avatar
    Dallas, TX
    Wayne I'll post some better pics when I'm at the new house showing the angles. With the wheels on it is very noticeable and it is at ride height.
    Nolan
  31. #231
    nkw8181's Avatar
    Dallas, TX
    Here's a pic showing the angle
    Nolan
  32. #232
    Administrator
    Enterprise Alabama
    You do have a ton of positive camber
  33. #233
    Administrator
    Enterprise Alabama
    Once you get the wheels that you are going to run, you can open up the upper IFS adapter bolt hole and bring the tire in closer to the upper ball joint and get more negative camber that way. Can you take a pic of the set up from above the upper A arm so I can see the relative length of each leg?
  34. #234
    A arm rough dimension
    The latest manual has starting rough dimension for the upper "A" arms.
    When threading on the couplers. Start at both ends at the same time. There is a stop in the middle of the coupler where it switches from RH to LH threads. This give you the most adjustability.
    The picture below is kind of bad, as it looks like one of the rod might be ready to fall out of the short coupler.
    The top of the picture is the front of the car.
    EDIT: MY MISTAKE, THE BOTTOM IS THE FRONT OF THE CAR.
  35. #235
    nkw8181's Avatar
    Dallas, TX
    The above pic is what I used but could not get to185.81. It bottomed out. I can't remember how much it was off but the shorter section is as above.
    Nolan
  36. #236
    nkw8181's Avatar
    Dallas, TX
    Wow I just realized it has been a while since I updated the progress on the car. After settling in after the move and removing the temp installed parts I've done a fare amount.
    Corrected brakes and blead them, trimmed upper arms, installed shifter and all linkage, e-brake, drivers seat, frame nose piece, radiator with hoses, air to water intercooler with heat exchanger (no hoses yet) and wrapped /installed exhaust headers. I think I caught everything and I just made a pic album to speed things up.
    http://imgur.com/a/EkXc3
    Nolan
  37. #237
    nkw8181's Avatar
    Dallas, TX
    Got the awic hoses installed and secured (minus the he return connection). Used clamps with zip ties and rivnut in various combination to secure both the awic hoses with the main coolant hoses. Also made a mounting bracket for the air intake.
    http://imgur.com/a/OZ9NX
    Nolan
  38. #238
    nkw8181's Avatar
    Dallas, TX
    Got my front wheels in, thanks VCP, and started on the monster call wiring. Uhgg I tell myself one wire at a time. Just one wire at a time. I'm trying to modify as little as possible until I know it starts.
    http://imgur.com/a/32qYF
    Nolan
  39. #239
    nkw8181's Avatar
    Dallas, TX
    Got my pre-order in for the hard top!
    Nolan
  40. #240
    Sep 2014
    Dallas, TX
    Your not the only one!
    joshuajach.com
