Mustang Convert
Got it now. I already knew about the 55psi setting - there have been a couple revisions to the Coyote install / controls pack documentation from Ford Racing. I have the latest version and it calls for 55psi.
What I actually mis-interpreted was the vacuum line statement. I read it as meaning no vacuum line should be installed at all. Not setting it at 55psi with no vacuum. My bad. What I still am curious about though is that I thought the process for setting fuel pressure was to do it when the engine was not running at all - just key on to run the fuel pump. This statement seems to imply setting it with the vacuum line disconnected and the engine running / idling? Anyone have insight here?
Kevin
russelljones48
Kevin,
That "I talked to Ford Racing" was a quote from an earlier post here. I did not call FR but did the Google searches which confirmed the 55PSI setting. I'm a ways away from the fuel system so I will recheck when I do that install.
rj
MKIV, IRS/TruTrack/3.55s, Coyote, TKO600, Wilwoods
Delivered: 1/6/2012
First Start: 1/19/2014
First Go-Kart: 2/1/2014
Graduation: 1/4/2015
Graduation Thread
