Results 1 to 40 of 74
Thread: Side Scoops - Teaser Pic
    Puyallup, WA
    Here are some teaser pics of side scoops that i intended sell as soon as i get a set fit and made on my car. Final detail of the mold will still take place.
    Jan 2012
    Take my money. Looks great so far.
    Puyallup, WA
    Im quite happy with how its looking. Needs a few more tweeks. Every time i look at it, i want to change something.
    Question: Exposed surface mounted fasteners or hidden?
    I want BIGGER!!!!
    Puyallup, WA
    I want BIGGER!!!!
    These actualy align with the front and rear wheel wells. Im considering making them oversize and cut to fit as need
    Hi I agree with Bob. If they were as wide as the rear wheel fender, another inch or so. Don
    Feb 2014
    Ramona, CA
    I vote for hidden fasteners.
    Puyallup, WA
    Quote Originally Posted by DMC7492 View Post
    You dont think that would look out of place?
    Kirkland, WA
    What are these scoops going to do ? Where do the they duct to ? Is that the duct behind the car ?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Clovis, Ca
    Hard to tell since they are black. I was getting ready to make a set out of aluminum. Save me the trouble, but its hard to see but I think they need to be bigger also.
    Thanks- Chad
    Jan 2012
    Hidden fasteners and a bit bigger for me too. They look good though where there at though.
    Puyallup, WA
    The ducts will be funneled back to my RMIC via ducting. The duct in the background is 12" and was used to collect the foam dust. Im thinking of using similar duct but black and 6" in diameter to funnel both scoops into the IC.
    As they sit now, they are approx 2.5" away from the body. My goal is to make them as large as possible but to not be an eye sore or something that looks out of place.
    My goal is to make them adjustable as far as front mouth opening goes and it'd be an easy trim to size desired and install.
    Next step after scoops is to make the funnel inside the duct.
    Jan 2012
    Are you planning on making them out of fiber glass to paint match or carbon? Is that 2.5" from the back or the front where the scoop indent is very shallow on the body?
    Puyallup, WA
    2.5" is measured at the widest part of the scoop where the original scoop indent starts on the side panel.
    Material is yet to be determined.
    Edmonton, Alberta
    Looks great Kurt, ground breaking as always! I agree with you on as big as possible without being an eye sore. From the angles your showing us, they could easily go bigger without looking out of place. Trim to fit would allow the wide tire guys to go bigger.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Puyallup, WA
    Hows this? About 3.5" opening. I think its perfect.
    Chicago, IL
    Hmmm, hard to tell with that along-the-fender view. A side or three-quarter view would help. As it stands, I think I prefer the smaller scoop - more elegant.
    And I vote for flush fittings. This isn't some jeep rock-crawler wannabe.
    Best,
    -j
    Executive Director
    The Community Garage
    Edmonton, Alberta
    Looks good Kurt, but we really need more angles of each scoop to give a worthwhile opinion.
    818 SRX - #91
    Arrived 01/02/2014
    Puyallup, WA
    I dont have the side amgles refined enough to post yet. I'll have something later today
    The bigger one looks Great! I like the top angle matching the rear fender angle. How does the contour blend back to the original opening? A nice curve or straight? Top View?? Great work!! Don
    Puyallup, WA
    Im almost done with the plug. The top angle will mimic the fender lines. Ill post pics tomorrow
    Edmonton, Alberta
    Now you're teasing without pics? That's just cruel...
    818 SRX - #91
    Arrived 01/02/2014
    Puyallup, WA
    The plug has been built. I should have my final scoops built and installed by next Saturday
    Jan 2012
    Very nice. I love the lines gives it a very aggressive look to the rear section of this car. At least from a side front view.
    Puyallup, WA
    Its been a lot of hard work to make the two sides identical. Im happy with the lines and fitment and they will definitely flow some air
    Edmonton, Alberta
    Looks great kurk! Planning on making them in carbon?
    818 SRX - #91
    Arrived 01/02/2014
    Or vacuum bag with West System Epoxy. The results would be extremely strong for the clumsy people we know and super light.
    Here is a quick vid. https://m.youtube.com/watch?v=LPXn038ahD4
    Clovis, Ca
    Those look good. I can appreciate the work you put in.
    I was hoping for a more rounded top part of the vent more like the rear fender form. But hey, we are all experts right? Beggars cant be choosers
    Again, nice work.
    Thanks- Chad
    south-central CT
    I'm with Chad. I like where you're going with this, and can appreciate all the work, but I think it would blend in better with all the other rounded surfaces if the top were rounded. Perhaps even pop-up a bit off the fender.
    Looks like 200% of what I have with the full open area on my sails.
    Any thought to developing top scoops to make the intercooler openings on the engine cover larger?
    Puyallup, WA
    Again, nice work.
    Im see the scoop lines similiar to the rear flares. Rounded over as part of the rear quarter and then pretty much straight as the flare. Sharp lines tend to not be as sharp on the finished product. Im going to produce a set before making any more design changes.
    San Diego Ca 92106
    It looks great, it's very similar to the lotus scoops.
    Since your so close to the wheel opening it "almost"makes sense to take it to the wheel well like a Porsche 935.
    Edmonton, Alberta
    Can we get any tips on the foam you used and techniques?
    818 SRX - #91
    Arrived 01/02/2014
    Puyallup, WA
    Extruded rigid foam was used. Glued with 3M Super 78 adhesive or expanding foam spread in between and weighted down over night.
    Shaping of foam was done with flap disk on a grinder. Final shaping was done with bondo And high build primer.
    Oh that is great!! I love the top angled portion! Aggressive as hell, powwwaaaaaaaaaaa lolll Great stuff Kurk, keep it building!!
    Member tebriel's Avatar
    WI
    Puyallup, WA
    First set came off the mold today. Need to attach the final mounting points for the top and bottom of the front. Ill post more photos once its fully mounted.
    Edmonton, Alberta
    That looks awesome! Really good work! Very aggressive scoop. Please don't be shy with the pics, we need angles!!!
    818 SRX - #91
    Arrived 01/02/2014
    Clovis, Ca
    I'll buy the first set. I need them before my race.
    Thanks- Chad
    Puyallup, WA
    PM sent
