Page 7 of 7 FirstFirst ... 567
Results 241 to 252 of 252
Thread: K818S Build Thread
  1. #241
    Quote Originally Posted by Kalstar View Post
    Car was baselined tonight (real tuning will happen tomorrow). Running rich and slightly out of tune due to the CIA... the car put down 190 wheel. SMG Motoring feels there is as much as 30hp left in the tune. We will see what she puts down after the tune. Keep in mind this is basically bone stock except for the CIA (stock airbox was cracked). Figured it is good info for all the builders building near stock to know what to expect. A stock WRX looses about 22%DLL (165-170whp) so we are picking up about 8% by eliminating the AWD.
    The car will be very enjoyable with that kind of power.
  2. #242
    Cape Cod
    Dyno tune is done. Results were 227whp/213wtq.
  3. #243
    Feb 2014
    Ramona, CA
    Yes, thanks for sharing this. Just to help clarify this WRX motor is a 2002 as stated on page 1.
    Now can someone do the same for a 2006?
  4. #244
    Cape Cod
    Yes 2002 WRX 2.0L with 86k miles.
  5. #245
    Freeport, ME
    That is using the bellmouth and 2.5 exhaust, muffler, no cat? Open source tune?
    Dan
  6. #246
    Exeter R.I
    Pretty much exactly what you wanted.
  7. #247
    Freeport, ME
    Makes me think my 05 with 70K, cone filter intake and 3 inch bellmouth, cat and muffler with stage 2 Cobb should be 230-240 as well... fingers crossed, we will know soon
    Dan
  8. #248
    Quote Originally Posted by matteo92065 View Post
    Matt,
    My engine is the same as a stock 06 WRX. See my post here http://thefactoryfiveforum.com/showt...l=1#post172896
    Kalstar,
    Lookin good.
    Do you know what your boost numbers were at?
  9. #249
    Just to clarify the exhaust uses the FFR turbo adapter and a 2.5" exhaust with a 2.5" Raptor turbo muffler.
  10. #250
    Cape Cod
    I would guess the muffler robs some power but I like the quietness far better then the 5-7hp I think it costs. As for the exhaust, when I bought it, it was spec'ed for the 2.0l, maybe the 2.5-2.0 exhaust is interchangeable. At current power levels it has a p/w slightly better then a 2015 Corvette Stingray (and that is assuming the 818 at 1910lbs). Should be a fun little rocket.
  11. #251
    Freeport, ME
    The turbo adapter goes off to the side, that goes straight... so that has the flat block off plate, no bell mouth? Makes me even more confident that with my setup 240 HP should be attained!
    Dan
  12. #252
    I just cut off the curved pipe and welded up what I needed to make it work.
