We got our 818 got R-Comps on our new race wheels today.
We searched for awhile to find race wheels. We wanted 15x8, 5x100 in the front, which is not easy to find unless you go to a fully custom 3 piece ($$$) wheel.
We wanted the 1" drop in wheel size, plus a lower diameter tire, in order to get about a 1" drop in ride height for racing. We are at 4" with the street wheels/tires (17x8 et 45 Enkei PF01 with Direzza Z2's in 235/40/17 and 255/40/17), and about 3" with the race wheels/tires (some rake as the front is lower).
We found some Axe Wheels, 15x8, 5x100, et 25, and ordered a set of 4. Despite being relatively cheap wheels ($600 for the set of 4), they feel like they are of pretty good quality. They're not the lightest or the heaviest at 16lbs each.
We did not think the 15" wheels would fit over the WRX brakes, but we lucked out! Perfect fit. Now to order some EBC Yellow brake pads, since we've confirmed we do not have to order new brackets/rotors.
Clear on the suspension as well:
We have two sets of tires for the front wheels - Hoosier A7's in 245/40/15 ($$$ and therefore saving for big clubs), and Hankook Ventus C71's in 225/45/15 (used, cheap, and will be used on our rough, local, small lot). Pictured are the C71's, with plenty of clearance at full lock.
The Axe Ex-8 wheels next to our Enkei PFO1's.
The rears are Drifz in 16x8, et 25, wrapped in Hoosier A6's in size 245/45/16 (bought on sale from Hoosier for $90/each!!!). They're not a perfect match to the Axe Ex8 wheels (aside from the color), but they are similar enough. We could not find a matched set of fronts and rears in the sizes/offsets we wanted. The Driftz wheels weighed in at 19 lbs.
Plenty of clearance:
Side by side:
We know that the A6's on the rear with the used C71's on the front could create some odd handling characteristics due to the tire differences, but our small local lot is very rough on tires and we will not be using it for set up anyway. For the bigger lots (NNJR and NER), we will run the Hoosiers all around. Since we bought 8 wheels total, we will have one "local" set, and one "big event" set. Eventually, we will run larger tires on the rear, but we are running square to start at the events that matter, and this staggered set locally.
Now to decide to stick with silver or black and paint the other half to match...
