Thread: Front tire 215/40/17 VS 215/45/17 ??
    Lansdale
    How bad will the fronts rub with the 215/45/17 tire? I have my wheels ordered (to FFR recommended size/offsets) and am torn between Dunlop ZII star spec in 215/40/17 (FFR recommended) and getting (what I really want) the new Bridgestone RE71R only available in the 215/45/17 (and currently with a $70 rebate)
    I am using steel lower control arms on my 818s. I gocarted with a set of 235/45/17's and they rubbed the corner aluminum very badly, but they are very tall (from my 12 wrx)
    Feb 2014
    Ramona, CA
    The OD is what matters right?
    215/40/17 is 23.8"
    215/45/17 is 24.6"
    I didn't answer your question, but thought it was important to add diameter info.
    I am looking at what it would take to fit a larger tire.
    Lansdale
    and a 235/40/17 is 24.4" And the fun part of being one of the early builders, waiting for the list of "this size will/won't work and why" before buying parts and finding out the hard/expensive way
    Frankfort, IL
    215/40/17 are the suggested size and already a tight fit. 215/45/17 seem to be possible, but difficult to squeeze in.
    http://thefactoryfiveforum.com/showt...learance-Issue
    http://thefactoryfiveforum.com/showt...mistake-I-made
    Suggestion: use google to search the site rather than the search box. just type your search term and then site:thefactoryfiveforum.com afterwards. found the above articles as the 2nd and 3rd results after this thread just by searching "215/40/17"
    Lansdale
    thanks
    FFR 818s #248 received 10/24/14
    first start 3/9/15 https://youtu.be/aRivN83ym-0
    first gocart 3/28/15 https://youtu.be/0Cq9LLzM_40
    first auto-x 4/12/15 https://youtu.be/4ada081tuks bloopers https://youtu.be/ZnBk0C-9uxE
    Body on auto-x Pocono pa 9/20/15 https://www.youtube.com/watch?v=chwtszG7vyg
    PA Titled and inspected 7/15/2016
    Senior Member AZPete's Avatar
    Stebru84, I bought 215/45/17 tires because the early manual listed that size but they rub badly on the frame and splash panel with a 2/3 turn. Soon I'll replace these with 215/40/17 so if you want to buy my two 215/45/17 Michelin Pilot Super Sport XL tires with only 5 miles on them, PM me. I paid $292 for them but will make someone a good deal.
